TOS 4.2.06 is released for update!
Ryzen
Re: TOS 4.2.06 is released for update!
Post by Ryzen »
Ryzen wrote: ↑10 Nov 2020, 18:45
TMroy wrote: ↑10 Nov 2020, 18:39
Ryzen wrote: ↑10 Nov 2020, 18:30 Can you help me ? For me remains blocked when the software is unzipped
The update package does not need to be unzipped.
I know, I'm not unzipped it. It's the process that does it. It's just to tell you when it blocks :
For those who would have the same problem as me, I renamed the / etc / base / update folder to updateold and relaunched the update
Problem solved
F2-210
4.2.06
Tricky
Post by Tricky »
Another question only just noticed this:
This update is not suitable for TOS 4.2.X beta.
So this update cannot be used if your running any of the beta versions? so what do you do if you want to update??
dimatola
Post by dimatola »
and when will the file appear for a clean installation, and not an update?
Tricky wrote: ↑11 Nov 2020, 19:05 Another question only just noticed this:
We will release the installation package After a while.It's estimated to be half a month.
mardook
Post by mardook »
After the update it does not allow me to access the various sections of hardware and power
sports_wook
Post by sports_wook »
Ryzen wrote: ↑11 Nov 2020, 18:02
Problem solved
This didn't fix it for me. Were there any additional steps besides renaming /etc/base/update to /etc/base/updateold?
mardook wrote: ↑11 Nov 2020, 22:35 After the update it does not allow me to access the various sections of hardware and power
Please clear the browser cache and try again.
scoobyfizz
Post by scoobyfizz »
macmpi wrote: ↑11 Nov 2020, 17:32
TMSupport wrote: ↑10 Nov 2020, 10:35 TOS 4.2.06 Release Notes
This update includes following bug fixes for the previous version, new features and optimized user interface:
It seems like this Release notes only reports changes compared to previous Beta.
However, 4.2.06 appears to be the first stable Release for 4.2.x cycle, and therefore Release notes should report meaningful changes since previous stable Release 4.1.32.
Remember most users are NOT Beta testers, and need to know what is new from previous stable Release.
There are several important new features introduced (folder quota on btrfs to name just one), that are worth mentioning at this point!
Stable release... your joking aren't you we have not had a stable release since I bought my nas 6 months ago.... so is this a proper release now not a beta?
Best thing I ever did was ebay my Terramaster...
mardook
Post by mardook »
TMzethar wrote: ↑11 Nov 2020, 22:49
it does not work by clearing the cache, even with a new pc
Ryzen
Post by Ryzen »
Hello,Try to change access. If you are accessing through http try https or something that has worked for me is to change the access port from https (5443 to 6443). I think it forces the web server to refresh the cache and the icons
F2-210
4.2.06
