TOS 7.0.0601 Beta (X86) is Released for Update
MikeZhang
Re: TOS 7.0 Beta: Boot hang, internal array drop (mdadm DeviceDisappeared), and Web UI failure on F8 NVMe
Post by MikeZhang »
AES wrote: ↑20 May 2026, 01:48
This error message is unrelated to the boot failure. We need more information to help with the analysis, such as the location where the computer is stuck on the monitor during boot.
exqo
France
Re: TOS 7.0.0601 Beta (X86) is Released for Update
Post by exqo »
I install TOS 7.0.0601 without any issue (for the moment).
But i found a translation issue in french version (not a big issue obviously)
F4-425 Plus (N95) - 2x4TB (Ironwolf) Traid + 1x8TB (WD Red)
TOS: 7.0.1278
RAM: 8GB
Bios: BJFX-TWLX-108
MikeZhang
Post by MikeZhang »
exqo wrote: ↑22 May 2026, 17:53
Thanks for the help, please help us with correct information to be displayed there
snapsh0t
Post by snapsh0t »
Some odd entries in the debug syslog file which occurred as I turned debug mode off. Whole log available if required.
May 23 07:28:09 Therver2 TOSDaemon[2795]: Successfully wrote file path=/etc/tos/debug/debug_cron.conf
May 23 07:28:09 Therver2 systemd[1]: debugmodel.timer: Deactivated successfully.
May 23 07:28:09 Therver2 systemd[1]: Stopped debugModel Timer.
May 23 07:28:09 Therver2 systemd[1]: Reloading.
May 23 07:28:10 Therver2 systemd[1]: /lib/systemd/system/rsync.service:9: Unknown key name 'IOSchedulingPolicy' in section 'Service', ignoring.
May 23 07:28:10 Therver2 systemd[1]: /lib/systemd/system/rsync.service:10: CPU scheduling priority is out of range, ignoring: 19
May 23 07:28:10 Therver2 systemd[1]: /lib/systemd/system/rsync.service:12: Unknown key name 'NICE' in section 'Service', ignoring.
May 23 07:28:10 Therver2 systemd[1]: Configuration file /lib/systemd/system/application.service is marked executable. Please remove executable permission bits. Proceeding anyway.
May 23 07:28:10 Therver2 TOSDaemon[2795]: running stop /etc/tos/debug/script/klogdebug.sh...
May 23 07:28:10 Therver2 TOSDaemon[2795]: shell /etc/tos/debug/script/klogdebug.sh running success
May 23 07:28:10 Therver2 systemd[1]: Condition check resulted in Kernel Security Modules - SMACK being skipped.
F2-425 Plus, 16GB RAM, 2 x 500GB WD SN700 EXT4 RAID1, 2 x 3TB WD Red EXT4 RAID1, TOS 7.0.<latest>
F4-SSD, 16GB RAM, 4 x 4TB SN700 EXT4 RAID10, TOS 7.0.<latest>
kai
Belarus
Post by kai »
Good afternoon. It's not possible to activate any user other than the administrator.
F2-223
TOS 7.0.0601
EriChan
Post by EriChan »
snapsh0t wrote: ↑23 May 2026, 14:48
To better assist you in confirming whether there are any abnormalities in the TOS system, please send the complete log to our technical support email at [email protected] via email, and attach the forum link and your forum ID as well.
AES
Post by AES »
The video surveillance system has stopped recording. It creates a single file within each half-day folder—and may even attempt to write to it—but to no avail.
(F8) A dedicated 1 TB SSD used for video surveillance is currently full; however, everything was working normally prior to this.
Despite this, messages indicating that old files are supposedly being deleted due to storage limits being reached appear regularly.
The designated recording directory is configured correctly, and new folders are indeed being created within the proper location. However, in reality, the drive is cluttered with old, empty folders dating back to last year, while the new folders are either empty themselves or contain a single file that cannot be played back.
The file sizes displayed in the screenshot are incorrect; in reality, the drive is filled with video clips—not just 528 MB of data.
What exactly does it delete? Files from the folder it writes to? There is such an unwieldy number of folders—hundreds of them—that I can't be bothered to sort through them all; they really should have been organized by year instead of dumping every single subscription into a single folder.
It seems to be working now—video files have started appearing.
It might be because I enabled a shared limit of 930 GB; previously, the limits were set individually for each camera.
I also manually deleted the old recordings.
TerraMaster F8, TerraMaster F2-425, Syno 218+
Riccobono67
Italy
Post by Riccobono67 »
Riccobono67 wrote: ↑21 May 2026, 18:18
CursaYang wrote: ↑21 May 2026, 09:16
Riccobono67 wrote: ↑21 May 2026, 01:00
Our internal tests show no lag issues when transferring files via SMB. Does the 2GB file you're transferring have a specific format?
Additionally, you can try temporarily disabling SMB multichannel and VFS MAC, then clearing the Windows SMB connection, and then testing the transfer again.
regarding an issue that appeared after updating the firmware to release 7.0.0601 on my TerraMaster F6-424 MAX (IP 192.168.20.109). Before the update (rel. 7.0.0567) I did not experience any anomalies.
Environment description:
NAS 1: QNAP TS-1685, IP 192.168.20.100. Shares three folders; one of these receives the backup from the TerraMaster.
NAS 2: TerraMaster F6-424 MAX, IP 192.168.20.109. Shares three folders with three PCs, Qnap and various devices.
Three PCs on the network have an active VPN that bypasses the local network for the NAS devices.
Jellyfin has been installed on the TerraMaster since purchase.
Symptoms observed after the update:
Any activity on the TerraMaster shared folders experiences micro-interruptions and freezes.
Video playback with VLC from SMB paths on the TerraMaster shows frequent interruptions and is not smooth.
File transfers to/from the TerraMaster show variable speeds up to zero throughput.
Disabling the VPN on one of the PCs reduces the issue but a slowdown is still noticeable.
The backup from the QNAP of the TerraMaster folder shows delays after the update.
FTP operations between the TerraMaster and the PCs do not present problems.
Streaming via Jellyfin (direct server streaming to TV, browser, smartphone, iPad, or laptops with the Jellyfin app) works correctly without interruptions. The issue appears only when accessing the same folder via SMB (e.g., VLC on PC).
The same file and operations on the QNAP (with or without VPN) do not show the issue.
Preliminary actions I intend to perform / plan to try:
Temporarily disable SMB Multichannel and VFS MAC on the TerraMaster.
Remove and recreate the SMB connection on Windows, then retest transfers.
Support request:
Could you tell me which logs or diagnostics to collect to assist your analysis (e.g., SMB logs, system logs, packet captures)?
Are there known settings introduced in 7.0.0601 that could cause these symptoms, particularly when VPNs are active on clients?
Any recommendations for further tests to perform (e.g., test SMBv2 vs SMBv3, temporarily disable SMB signing, check VPN MTU/keepalive)?
Is a patch or recommended rollback planned if this release is confirmed as the cause?
I am available to send logs, configuration files, or run tests by appointment. Thank you for your help.
Best regards,
Cesare Riccobono
For those who have experienced issues with SMB sharing while VPN is active on the PC, after several attempts I managed to solve the problem by enabling the **Discovery Service**, in particular the following options:
UPnP, WSDD, and Bonjour.
exqo
France
Post by exqo »
MikeZhang wrote: ↑22 May 2026, 22:18
it should be : "Temps d'activité" !
TOS: 7.0.1278
RAM: 8GB
Bios: BJFX-TWLX-108
exqo wrote: ↑24 May 2026, 03:45
This has been added to the bug tracker. We will review and fix it as soon as possible. Thank you again for reporting the issue. :)
