6.0.420 beta update is not more available.
I'm currently running TOS 5.1.145. What are my options to install/upgrade to TOS 6?
i can not get lacp performance out of this. i have proven the windows server to provide 2gb to other clients however i cant push/pull data to the f6-424max
the best i can get is only one nics worth of performance. i have tried each of the bind options, both with and without lacp attempted. i have also tried with the server out of lacp and just trying to smb multi channel route. still no possible configuration seems to work to make this go past 1gb
TOS version 6.0.531-00150clonea1 wrote: ↑07 Nov 2024, 14:29 i can not get lacp performance out of this. i have proven the windows server to provide 2gb to other clients however i cant push/pull data to the f6-424max
The version doesn't match, you should post it here.
viewtopic.php?t=6816
It doesn't even look like it's reaching the 1 NIC limit. Could be a bottleneck in the storage or network lines.
What is your storage configuration?
i know my fabric can do that band width i have also played the cable game, i believe it to be configuration related as the tnas never tries to use the other nic and it holds it right at the capacity of that nic.TMzethar wrote: ↑07 Nov 2024, 18:46The version doesn't match, you should post it here.
6xred 18TB in TRAID+ these drives them self in single disk configuration are more than enough to saturate a single 1gb/s (125MB/s) link as these drives will do 220MB/s on large sequential writes. if we are conservative and say that 2 drives are parity and not used for reading striping then that leaves us 4 drives so 880MB/s or roughly 7gb/s
TOS is a specialized web-based operating system for TNAS devices, with TOS 6 marking its sixth-generation release. This latest version offers a completely revamped interface and over 40 new functions, plus improvements to more than 400 existing features.pixel car racer pc Designed to deliver an outstanding upgrade experience, TOS 6 enhances data security and streamlines storage management, providing TNAS users with an advanced and user-friendly solution for their storage needs.
Hello, where can I download the update file? My f4-423 has 5.1.145 and I wanted to update to 6.0.
The new version of the TOS system can be found on the official website for the new model devices. For series updates, visit: viewtopic.php?t=6984
