emperorgr
Greece
Post by emperorgr »
hi i am on 6.0.229 for F2-422 and cannot find further updates either via GUI or...other links, any idea how can I go higher in final Tos 6 build? :roll:
emperorgr wrote: ↑14 Oct 2024, 04:38
Afraid you will have to wait until the update packages are rolled out for the various devices. > .229 is a big step and needs to be taken carefully.
emperorgr
Greece
Post by emperorgr »
Gremlin wrote: ↑14 Oct 2024, 06:22
so there aren't any public above > .229 update packages? or are not final to use
Tricky
Post by Tricky »
I have been running my F5-221 on TOS 6-0-229 for a while without a problem other than not being able to update, now all of a sudden it kees appearing dead when and off line and requires rebooting but just does the same again, any ideas why its suddently decided to play hide and seek?
And before I end up reverting to TOS 5 is there any chance in the near future of these updates aimed at those using 6-0-229 so we can keep the system going or is it going to be as q-u-i-c-k as the original TOS 6. :roll:
Tricky wrote: ↑15 Oct 2024, 18:11
There will be available upgrade packages to allow TOS 6.0.229 to be upgraded to the official TOS 6 version.
emperorgr
Greece
Post by emperorgr »
TMzethar wrote: ↑15 Oct 2024, 19:56
any timeframe?
That is all very well. However, at a certain point in the past it was stated that only devices manufactured after a certain date would be able to upgrade. Despite questions being posed, nothing was ever made clear as to what would make the difference nor was it made clear what the device serial numbers were applicable to the cut off. None of this detail has ever been repeated amongst your promises of updates 'coming'. Should we understand now that the manufacture date was a 'red-herring' and all devices such as Fn-221 will update seamlessly regardless.
I have been looking at used Fn-221 models on ebay for example. I realised that some older serial nos do not have the hdmi port that is installed on my examples. So, a serious hardware difference makes older models incompatible.
Some clarity is required please.
emperorgr wrote: ↑15 Oct 2024, 20:37
Probably within 1 to 2 weeks.
emperorgr
Greece
Post by emperorgr »
TMzethar wrote: ↑15 Oct 2024, 20:58
great thanks!
robertosandoval
Mexico
Post by robertosandoval »
I've already downloaded the update file TOS_X642.0_Update_6.0.420_00019_2407300950, but it has CRC errors. Could you send a link to download it?
