The Brand New TOS 5 is Released!
Charlie_Croker
Saudi Arabia
Re: The Brand New TOS 5 is Released!
Post by Charlie_Croker »
@TerraNas2 wrote:
That warning can normally be ignored ( I have had to reinstall the beta a number of times), But have a backup just in case.
1. Download the TOS5 image and save to desktop of your PC/Mac
2. Shutdown NAS
3. Pull the drives from NAS
4. Power on NAS
5. When prompted about no HDDs, reinsert disks then wait for them to be checked
6. Now install the TOS 5 image from your desktop
7. When prompted setup Superuser Account and then it should be plain sailing
TerraNas2
Post by TerraNas2 »
> 2. Shutdown NAS
> 4. Power on NAS
Thank you. I really wish that warning was removed or stated clearly that it wouldnt delete existing data. As by the time you see it, its too late to do a backup since you have already wiped TOS.
I regretted doing the update, and stalled at that warning thinking I was screwed, and support gave me mixed messages, live support said I would lose the data but email support said it was normal and wouldnt. I proceeded after your post and everything turned out fine in the end. TY.
scout71
Italy
Post by scout71 »
TNAS for Android? when will it be done?
Charlie_Croker
Saudi Arabia
@scout71 wrote:
I've given up on this happening, I use Foldersync and Fie Explorer apps and both work well.
Roccia7
Italy
Post by Roccia7 »
I used those apps too, but then I switched to resilio sync which is much simpler. Have you ever tried it?
scout71
Italy
Post by scout71 »
> and both work well.
I have not tried any of the proposed options ... I think I have to study a little ... Thanks!
super-6-1
Post by super-6-1 »
i keep seeing "Custom" but im not seeing where this is. what am i missing? am i the only one? All i see is automadic install or Manually download and install from TOS. Am i missing a step?
When i used the Manual option i get Installing has TOS failed! Please restart TNAS and try again i have done this a few times with no success.
Note: I couldn't edit or delete my last post. Sorry mods.
{L_BUTTON_AT}super-6-1
Before you can install TOS 5, you need to update your TOS if your version is earlier than 4.2.32.
super-6-1
Post by super-6-1 »
I can not check it but I did all the updates before doing this. I did try to past the initialization process but it fails every time. Is there anything I can do? Iv tried both automatic and manual and every time it fails.
super-6-1
Post by super-6-1 »
Apone doing the reinstall and upgrade process to 4.2.3x i still do not have this "custom" your guide is saying, is there a screen shot?
