[Help] Unable to access my F5-422, visible to router
TMlinda
Re: [Help] Unable to access my F5-422, visible to router
Post by TMlinda »
brian666 wrote: ↑26 Sep 2025, 22:37
Regarding the problem you encountered, we recommend that you contact LiveChat on our official website to schedule a remote inspection so that we can quickly troubleshoot the problem for you. https://www.terra-master.com/
brian666
Post by brian666 »
I'm very puzzled. I had an appointment for you to do your remote inspection, but my ISP decided otherwise, my internet connection was down when it was supposed to happen. I did my best by sending you a cancellation from my phone about 6 or 7 hours (my early evening) before the remote inspection was due to take place.
I then sent you a message asking to make another appointment, but got a reply stating that my problem was now fixed (it isn't, of course) and to post here again if I needed further assistance?
OK, so as requested, here's the post. Nothing has been done to my TNAS, the desktop is still inaccessible, and I would expect that you will still want to do a remote inspection. As long as my ISP provides a working internet connection at the time, how do I make another appointment?
TMbuddy
Post by TMbuddy »
brian666 wrote: ↑01 Oct 2025, 21:17
Hello, the technical support mailbox has received and replied to your email.
AlAleksiev
Post by AlAleksiev »
Hey Brian,
Did you made some networking troubleshooting before to dive in the storage direction?
I mean, look at the information, shared so far:
  • new router and the problem started (sounds like a trigger)
  • storage is with new IP address and with differenrt 3rd octet (sounds like a different subnet)
  • router can reach the storage (I guess ping, but it's good to be clarified)
  • your PC cannot reach the storage when using TNAS desktop app
  • your PC still can reach the storage somehow (there were no details how exactly)
Could you clarify few deails from the above incomplete conditions picture:
- what is the IP & mask of the storage? (if you cannot identify this from the router, just connect one HDMI monitor and one USB keyboard to the NAS and check it from CLI)
- what is the IP & mask of your PC and can you traceroute the NAS from it? (share the trace output for clarity)
- how exactly your PC was able to reach the NAS? (ping, smb, nfs, ssh, telnet etc.)
- how your PC and the NAS are connected to the LAN? (describe the physical layer)
Cheers,
Alex
______________________
F5-221; 10G RAM; 5 x 4TB TRAID; Riser, Power and/or ASMedia HW failure undetected by TM Support
F6-424; 32G RAM; 2 x 512GB 8Gb/s M.2; 6 x 4TB raidz2; TrueNAS 25.10.1
¯¯¯¯¯¯ Jellyfin, Pi-Hole, Unifi Controller, Zabbix
Return to “Initialization”
