Public Beta Testing for TOS 6 ARM Version
dikol
Re: Public Beta Testing for TOS 6 ARM Version
Post by dikol »
hk87 wrote: 17 May 2025, 22:34 However, there are difficulties when reinstalling Docker. This is not displayed in the application and cannot be found in the store. The Snapshot and MultimediaServer apps were ready to start immediately.
Install Docker from TOS5
TNAS F4-212 2Gb TOS 5.1.73 2x4Tb Seagate SkyHawk ST4000VX016 2x8Tb Seagate Ironwolf ST8000VN004
TNAS F4-210 1Gb TOS 4.2.44 2x2Tb HGST HUA723020ALA640, 1x4Tb Seagate SkyHawk ST4000VX016
ColaChen
Post by ColaChen »
"5. Surveillance Manager, iSCSI Manager, Portainer, Docker Manager, and developer tools will not be available in this version. If you have related data, back it up before updating."
Please note that version 6.0 currently doesn't include the Docker Manager application.
Seamas73
Post by Seamas73 »
dikol wrote: 17 May 2025, 23:54 Install Docker from TOS5
Do you mean manual install docker.tpk from /Volume1/@cache?
You think it will work on TOS 6.0?
Is it possible to install docker engine on TOS 6 via apt package manager?
dikol
Post by dikol »
Seamas73 wrote: 20 May 2025, 13:54
I tried to install packages from TOS5, for example Surveillance Manager, qBittorrent and jellyfin. They start. I go to the Surveillance management interface. There is no IP camera, I can't fully check the work. Jellyfin and qBittorrent works. I haven't checked Docker.
The apt package manager works, I installed several packages to check
Seamas73
Post by Seamas73 »
Well, I'll wait some more then.
I don't really like experiments: I tried to copy TorrServer.MatriX on TOS 5.1 without docker and force it to run, but I can't wrote proper init script (I'm not experienced in bash scripting and DeepSeek didn't help me either). As a result of my attempts f2-212 began to work terribly slow.
I had to reset device and reinstall the system.
hk87
Germany
Post by hk87 »
ColaChen wrote: 18 May 2025, 10:23
Thank you very much for the quick reply. Please excuse my oversight.
jor3l
Columbia
Post by jor3l »
does docker work just not the app? or it doesn't work at all
Mysh
Micronesia
Post by Mysh »
Hi! :) I just installed the TOS 6 beta on my F4 212 2g. It's awesome, thanks! Are there any plans to bring Terrasync to ARM / The F4 212?
Seamas73
Post by Seamas73 »
jor3l wrote: 24 May 2025, 01:53 does docker work just not the app? or it doesn't work at all
I think docker daemon installs with docker manager, so if you can't install docker manager you can't get docker daemon. Unless you add docker repo and install docker daemon via apt package manager.
OrionXie
Saudi Arabia
Post by OrionXie »
Mysh wrote: 24 May 2025, 06:30
Thank you for your feedback. I haven't seen that plan yet, so please keep an eye out for notifications about future updates.
