TOS 4.1.30 is released for update
Re: TOS 4.1.30 is released for update
Hardfecx wrote: 11 Aug 2020, 22:11
TMroy wrote: 11 Aug 2020, 21:44 Please follow the instructions to download the new update package viewtopic.php?f=28&t=711
I have no more acces to the Terramaster interface
viewtopic.php?f=75&t=423
Hardfecx
Post by Hardfecx »
TMroy wrote: 11 Aug 2020, 23:49
I told you i have no more access to the interface...
yorch
Post by yorch »
Hardfecx wrote: 11 Aug 2020, 14:50 I was now on the TerraMaster webite, under "Download" there is no tos Version for the F4-210.
Thats why it can't download it manually.
What schould i do now?
F2-221
yorch
Post by yorch »
Hardfecx wrote: 12 Aug 2020, 00:29
F2-221
Clean your browser cache or change to another browser like google chrome, Firefox or safari.
brianx87
Post by brianx87 »
Still getting random high CPU spikes causing the fan to go into full speed since 4.1.27
Hardfecx
Post by Hardfecx »
TMroy wrote: 12 Aug 2020, 02:47
That's what I dd but no possibility to reach the interface. When I try to install a new Tos version, the nas rest stuck even after 15 minutes it's still the same
Tricky
Post by Tricky »
OK just read the release notes posted and it says that video trans coding can now be done from the website which i have just tested and no it doesn't support h.264 which is all i have tested so far yet just talked to my friend who is running the 4.2.01 says this will decode h.264?
Hardfecx wrote: 12 Aug 2020, 16:55
please replace a healthy hard drive and try again. if you still got problem there, write an email to support(at)terra-master.com, tell your story and ask for help.
Tricky wrote: 13 Aug 2020, 16:37 OK just read the release notes posted and it says that video trans coding can now be done from the website which i have just tested and no it doesn't support h.264 which is all i have tested so far yet just talked to my friend who is running the 4.2.01 says this will decode h.264?
hi Tricky, nice to hear from you!
To use the transcode feature, you need to install an app "Multimedia Server", and enable the transcoding in settings.
