I have a T6-423 which was running on version 5.1.131 and I manually updated to version 5.1.145.
I have two storage pools and two volumes.
Volume 1 and Storage Pool 1 = 6 x 12TB hard drives (RAID 6)
Volume 2 and Storage Pool 2 = 1 x 2TB NVME SSD (TRAID)
Problem: Since upgrading I cannot access Volume 1 anymore - the files do not show in the file manager and the mapped drive in Windows does not work anymore.
I can still access Volume 2/Storage Pool 2 fine.
What I think happened in version 5.1.131 - I created Volume 1 and Storage Pool 1, then I installed a NVME SSD and created Volume 2 and Storage Pool 2.
Later I deleted Volume 1 and Storage Pool 1 and remade Volume 1 and Storage Pool 1. There was a mismatch of names at some point where it showed Volume 3 on same areas on TOS but volume 1 on other areas.
I think with the upgrade, the system has now got confused not knowing if it is volume 1 or volume 3.
Any idea how I can get access back to my volume and files?
TOS 5.1.145 (X86) is Released for Update
Re: TOS 5.1.145 (X86) is Released for Update
Works fine on my F4-420. Thx
F2-221 6 Gb RAM - 2x8TB
F4-425 16 Gb RAM - 4x4TB
- doumlapointe
Works fine on my F2-221
Updated from 5.1.67
Thanks!
Updated from 5.1.67
Thanks!
F2-221, TOS 5.1.145 (8GB system partition), 2 x 4TB RAID0, Plex Media Server
UncleJohnsBand
Worked fine on my F5-221. No issues during upgrade or post upgrade.
Just updated without any issues.
F2-220, OMV 7.5, Docker (Nextcloud, AdGuard Home, immich, File Browser, Stirling PDF)
Erfolgreich aktuelliert von 5.1.131 auf 5.1.145!
Augsburg/Deutschland
F4-424 PRO
F4-424 PRO
I have F2-423 still on 5.1.131, when I hit the check update button, I get that I'm on the latest update. Is this an error, or do I have to do the manual update of the device?
F2-423 2x4TB
Yes, use the manual update. Download link is in post #1 of this thread. {Tos5 updates were not 'pushed'}
when can we expect the release of the update from 5.1.145 to TOS 6.0.***?
F4-424 Pro
F2-210
F2-210
