Docker engine not enabled on reboot
Discussion about Docker
EthanLiu
Re: Docker engine not enabled on reboot
Post by EthanLiu »
RDHoworth wrote: ↑13 Aug 2024, 23:46
Hello, what is the version of your system? How do you set up startup tasks? When creating the container, did you select the "Start on boot" option?
RDHoworth
Post by RDHoworth »
The system verion is 5.1.145.
I created all the containers using Portainer, but just checked them with Docker Manager, and Start on Reboot is enabled for all of them.
Regards, Richard
TMeric
Post by TMeric »
RDHoworth wrote: ↑14 Aug 2024, 19:32 The system verion is 5.1.145.
Regards, Richard
Thanks for the information.
We have verified similar issues. A new version will be released in the near future. Or it can solve your problem. Please wait.
RDHoworth
Post by RDHoworth »
OK, Thanks
makhai
France
Post by makhai »
I experience same issue with my f4-424 pro freshly setup (5.1.145)
It will be solved with a TOS 5 or TOS 6 release ?
TMlinda
Post by TMlinda »
makhai wrote: ↑21 Aug 2024, 19:23
Please wait, the new version can be detected in the application center after it is updated.
RDHoworth
Post by RDHoworth »
Hi, is there an ETA for this update?
RDHoworth wrote: ↑21 Aug 2024, 21:04
The time has not yet been determined.
Return to “Docker”
