New TOS 6 File Management Experience
jpeckinp
Re: New TOS 6 File Management Experience
Post by jpeckinp »
Is there a specific process that I should see running while a traid array is being repaired?
I'm running TOS 6 .436 on a 424 Pro. Volume and Storage Pool say degraded and I started the raid repair but nothing acknowledged that it is running.
I do see my W/R is high around 400MB/s but CPU is around 4% and load is around 10%.
EDIT: Well scratch that after 20 minutes it finally said it is rebuilding.
So if any one else notices this issue just wait a while it will start.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
TMnight
Post by TMnight »
jpeckinp wrote: 07 Aug 2024, 07:35
Array degraded is often caused by certain reasons, leading to the detachment or failure of hard drives that originally participated in building the array. Once the repair process is initiated, the system should automatically trigger a notification and start the repair progress, with the synchronization progress of the storage pool and volumes displayed in real-time as a percentage on the interface. If the notification does not appear, it may be due to browser cache issues. In this case, it is recommended to try clearing the browser cache and re-logging into the TOS system.
DSBergin
Post by DSBergin »
The help files say that holding either the control or shift key, should allow for multiple file selection, this does not work on macOS, holding Shift Key will allow for selecting a number of file in a consecutive sequence with UP & Down Arrow Keys or with the mouse cursor, but if you try to skip a file and select it with the Shift Key it will deselect the previously selected files & select the file under the mouse cursor.
If you try to use the Control Key & mouse to select individual files, the previously selected file or files are deselected and the file under the cursor is select, on macOS you can use the Command Key & mouse to select individual files, but that does not work in file manager either.
Is there a way or keyboard & mouse combination that will allow, for the selection of multiple files in macOS Ventura, accessing the TOS interface through Firefox.
XtinaLover
France
Post by XtinaLover »
DSBergin wrote: 15 Jan 2025, 18:03
It sounds like you're experiencing issues with file selection behavior on macOS Ventura through Firefox while accessing the TOS interface. The behavior you're describing where the Shift and Control keys don’t work as expected with multiple file selections is unusual, especially when compared to the standard functionality of macOS file management.
On macOS, generally, the Command key (⌘) should allow you to select multiple non-consecutive files, but it seems like this isn’t working in the file manager interface you're using, and that could be due to how the web interface is implemented or a conflict with browser settings.
F8 SSD Plus; 6.0.610; 2 x 1024G KC3000 PCIe 4.0 SSD;
:idea: Dans l'ocean des données, le stockage est mon bateau.
