OneDrive
Re: OneDrive
It is currently being tested, and will be released after the test passes. I will notify you after the release. Update will handle moving file within the sync folder.
gargs.manish
Re: OneDrive
Post by gargs.manish »
Any update on this? and will this update work on latest system upgrade?
I have ad issues with latest system upgrade which required OneDrive to delete all configuration and reinstalled again.
Re: OneDrive
Which system version did you upgrade to the latest system?
You need to uninstall, reinstall and reconfigure related information.
We should update onedrive tomorrow.
gargs.manish
Re: OneDrive
4.2.08-2101111540
gargs.manish
Re: OneDrive
It's been almost two weeks waiting for updated OneDrive app. Do you really plan to fix issues and by when?
Re: OneDrive
The app has been updated, you can check it out in the app center.
Return to “CloudSync”
