TOS 5.1.37 (X86) is Released for Update
Re: TOS 5.1.37 (X86) is Released for update
{L_BUTTON_AT}UncleJohnsBand
From your description, it seems that you are still using TOS4 or your browser still keeps the browser cache of TOS4? If TOS4, it doesn't have these pages yet.
UncleJohnsBand
Post by UncleJohnsBand »
Correct..... Still on TOS 4
DERIKKU
Post by DERIKKU »
{L_BUTTON_AT}DERIKKU
TMwuu wrote: ↑28 May 2023, 18:12 You can try to clear the SMB access records and restart the SMB service.
Well but after a restart this dummy folder are alive
F5-221
TNAS 10TB
RAM 10GB
maexchen
Post by maexchen »
so, my / says "1.69/1.84 (GB)" (under 5.1.33) does that mean I have reached the end of the road and there won't be any ToS updates for me anymore? not even security or bug fixes?
skifatterunz
Post by skifatterunz »
F2-220.
Updated to 5.1.24, my "/" was 82% space occupied (more or less)
Updated to 5.1.33 and reinstalled Plex, the only external app installed.
My / now is 97.8% space occupied: 1.69/1.84 GB (terrible!)
I start to learn quickly Linux fundamentals, via SSH find in /etc/base/update the file TOS_X642.0_Update_5.1.33_00360_2304141548.bz2, I think useless now.
I delete it.
Then check the "/" in System info -> Overview and I have 84.1% space occupied (wow! :-D)
The question is: there are dir or files obsolete or useless to safe delete from disk in dir "/" or "/etc/" (for me, data from old unused and deleted apps like Emby Server, replaced by Plex), to reduce space occupied from root partition?
Few days ago, TMroy in this post viewtopic.php?f=76&t=4655&start=30#p27094 say "Find the guideline from solution B to delete some system files to release storage space." but the link open a forum page written in chinese...
topo01
Germany
Post by topo01 »
maexchen wrote: ↑30 May 2023, 01:22 so, my / says "1.69/1.84 (GB)" (under 5.1.33) does that mean I have reached the end of the road and there won't be any ToS updates for me anymore? not even security or bug fixes?
Here they announced they will provide a solution: viewtopic.php?f=76&t=4655#p26822
So let's wait.
F2-220, OMV 7.5, Docker (Nextcloud, AdGuard Home, immich, File Browser, Stirling PDF)
scout71
Italy
Post by scout71 »
TMRyan wrote: ↑27 May 2023, 18:39 WARNING!
Since the new version of TOS 5.1 system requires more storage space, if your initial system was TOS 4.x and system partition is 2GB, please do not update to this version.
Okay, my system has less than 2Gb, there is a way to increase space? I would not like to stand still with the updates as there are still problems in the current system that I wish were correct. Thanks!
jduraper
Spain
Post by jduraper »
Hello, I stay having problems for get an external connexion to Tnas from Tnas mobile3, is impossible to open connection out of wifi range, this is new after update to 5.1.37, I tried activate the tick selection on Remote Access in of TNAS but it was impossible, check it. in this link I have add screen shots from Tnas server, https://drive.google.com/drive/folders/ ... sp=sharing
My TNAS is a F2-221 under TOS 5.1.37
norman0
Germany
Post by norman0 »
With this update, the fan control no longer works on the F2-220. If I set it to "automatic", the fan always runs at about 1500 rpm. The CPU load is around 5% and the temperatures are also in the normal range. With TOS 5.1.34, the fan was mostly off or ran very slowly. Now it is audibly loud.
F2-220 4GB + 2*Seagate IronWolf 4TB
liammcmullan
Post by liammcmullan »
Installed with no issue.
