Time Machine Error BACKUP DISK DOES NOT SUPPORT THE REQUIRED CAPABILITIES
Time machine backup for macOS users
Re: Time Machine Error BACKUP DISK DOES NOT SUPPORT THE REQUIRED CAPABILITIES
Firstly make sure the SMB, AFP file service and Bonjour service have been enabled on the control panel.
Secondly, you need to enabled the Time machine backup from "Backup" on TOS desktop, and set a backup shared folder to your backup task.
At last, before you doing a Time Machine backup, go to Go > connect to server, connect to your nas service via AFP file service.
ninjaadmin
Post by ninjaadmin »
i have the ans for this problem, i was having the same identical issue, this is how it worked for me:
you just have to use Afp://192.168.1.x
x is the address of your machine.
once you make the network drive on your mac DONT USE SMB://192.168.1.x , since time machine will not recognize it.
go to the settings on your time machine and your network drive will be there to be used.
ninjaadmin wrote: ↑05 Nov 2020, 14:23 i have the ans for this problem, i was having the same identical issue, this is how it worked for me:
In most cases this really works.
SCX
Post by SCX »
I have the very same issue. I really hope this can be fixed. Any luck guys?
Return to “Time Machine”
