TNAS mobile is applicable to Android 8.0 and above mobile phone system.
TNAS mobile 3 Beta is released for testing NOW!
TWlhq
Re: TNAS mobile 3 Beta is released for testing NOW!
{L_BUTTON_AT}dataonly
To run the latest mobile app, your android version is requested to be at least 8.0. iOS app is coming soon.
Pixel 7 isnt supported. With the latest APK
- crisisacting
- Silver Member
They'll need to either add 64-bit (AArch64/ARM64) to their future APK releases if they want to support the Pixel 7 series and future devices, because it is currently only 32-bit (v7a, ×86); it's not an API level issue, since they didn't set a maximum API level on their app.
the latest beta does not load. 11 was doing very well. I also tried to clear the app memory but it still won't load. I reinstalled version 11 and everything works
I figured it wasn't 64bit compatible.crisisacting wrote: ↑16 Oct 2022, 15:36They'll need to either add 64-bit (AArch64/ARM64) to their future APK releases if they want to support the Pixel 7 series and future devices, because it is currently only 32-bit (v7a, ×86); it's not an API level issue, since they didn't set a maximum API level on their app.
- runrunrun2022
The app is requested a 4 digit verification code along with my account and password. Where do i find the verification code? I set up the OTP which provides a 6 digit code.
{L_BUTTON_AT}runrunrun2022
would you provide a screenshot? not able to understand your meaning.
@tmroy
Are you guys planning on 64bit support? Google is doing away with 32bit apps.
Sure, will release 32bit and 64bit compatible version soon.
