TerraSync Windows Client
TerraSync is a cloud drive service application that helps users build their own private cloud drive services with their TNAS devices.
Theo
Re: TerraSync Windows Client
Post by Theo »
Is there an update on this? I literally just bought an F2-212 based in large part on the prospect of using TerraSync to create a cloud storage system for my friends.
ElPabloMaximo
Post by ElPabloMaximo »
I think the only client availble is also for the TerraMaster which does not really help in regards of a personal cloud solution. I can't find any client for any OS out there.
T12-450
TRAID Pool 1 - 2x2TB NVME
TRAID Pool 2 - 4x4TB HDD
TRAID Pool 3 - 4x6TB HDD
https://www.linkedin.com/in/paul-tippit-56496b17/
Theo
Post by Theo »
Despite being a feature specifically named on the F2-212 page, and mentioned in several reviews I've seen, I can't even find the app on the device itself.
ElPabloMaximo
Yeah, I feel a little misled also. Perhaps its a delay caused by transition from TOS 4 to 5?
T12-450
Theo
Post by Theo »
TMroy wrote: 26 Sep 2023, 22:32 The TerraSync client for windows does delay quite a long time from our schedule, we are sorry about that. But what does this have to do with the advertised function? TerraSync for windows is not a promised feature when you purchase TNAS, nor is it part of the service you purchased.
TerraSync is literally a listed feature of the F2-212 device I purchased. That means it *is* a promised feature.
It is listed under "Rich Backup Solutions" on the F2-212 product page. (https://www.terra-master.com/us/product ... 2-212.html`)
Is there an ETA you can provide on when that promised feature will actually be available?
DigitalAnalog
Australia
Post by DigitalAnalog »
Hi - where is the TerraSync Windows client?
F4-423
TMlinda
Post by TMlinda »
DigitalAnalog wrote: 16 Apr 2024, 07:10
You can refer to this link: viewtopic.php?t=5457
samius
Post by samius »
If use TerraSync on one pc, but with different windows accounts, TerraSync stops working with unexpected error.
F4-424 MAX TOS 7
TMlinda
Post by TMlinda »
samius wrote: 30 Nov 2024, 06:28
Thank you for your feedback. Currently, the normal operation of TerraSync on PC requires administrator privileges.
samius
Post by samius »
Both accounts on the PC are local admins.
F4-424 MAX TOS 7
Return to “TerraSync”
