Add quota for TimeMachine shared folder
Re: Add quota for TimeMachine shared folder
Since 4.2.06 Folder quota is possible on btrfs filesystem (only).
I therefore created a Backup share with 1GB quota: that share is selected as TimeMachine folder.
However, on the Mac side, TimeMachine system does not report the 1G volume size, but the full NAS Volume size...
This may cause issues when quota is reached: unexpected file write error, instead of automated TimeMachine pruning which is what is expected.
TimeMachine server should properly report the quota value if set.
Thanks for consideration.
TMS
Thanks for the report, we will verify it here first.
TMS
TimeMachine system reports the full NAS Volume size.The purpose of quota is to limit the capacity of shared folders in the case of multiple users, and control the amount of data placed in shared folders, so when backing up, pay attention to whether the file size exceeds the quota
@TMS, I think you miss the point.
Thanks.
We are now post 4.2 release now, when can we expect this feature, which of course shall make sure TimeMachine server does report the proper limited size allocation.
Thanks.
{L_BUTTON_AT}TMRyan
Can I ask for this feature to be included very soon.
I am running a bodged workaround to get this working but it needs files to be edited after every re-boot which is a pain.
The problem here lies with the with AFP implemented by Netatalk.
Originally Apple provided a configuration for time-machine which allowed you to specify the size limit of the time-machine backup.
Apple, in their lack of wisdom, removed that functionality.
Netatalk, at the time, offered a solution in the form of the afp.conf line:
But this wasn't a true limit - It was based on a calculation that reported the size limit minus the size of a Time Machine Backup. If anything else was added to the file share it didn't report correctly - So if you only use the file share for Time Machine backups - Happy days, except.....
Here are the problems with TOS.
1) You can set up a folder for sharing as a time machine folder and set a size limit, however AFP/Netatalk does not report this limit to OSX
2) If TOS added a into the afp.conf file that would work OK for Time Machine Backups. The would need to be 95% of the size of the shared folder size limit to account for the vagaries of the calculation run by AFT/Netatalk.
3) This doesn't work for Catalina (and I'm assuming for Big Sur) since the AFP calculation is looking for a file ending in but Catalina uses a
4) AFP/Netatalk hasn't been actively maintained for 3 years or so.
5) If you decide to modify the afp.conf file yourself it's recreated at every system restart and every restart of any of the file sharing services and over-writes the file removing any modifications you have made.
I suggest the TOS developers adapt a simple fix.
1) Modify to write the relevant to the Time-Machine shares based on the btrfs size limit applied to the shared folder or offer an option when setting up a Time Machine share to limit the size there - Allowing for the 95% factor
2) Run a routine that occasionally looks in the Time Machine shares and if it finds a file and add a symlink
A quick fix to resolve the problem perhaps.
vol size limit=kbBut this wasn't a true limit - It was based on a calculation that reported the size limit minus the size of a Time Machine Backup. If anything else was added to the file share it didn't report correctly - So if you only use the file share for Time Machine backups - Happy days, except.....
2) If TOS added a
vol size limitCode: Select all
vol size limit3) This doesn't work for Catalina (and I'm assuming for Big Sur) since the AFP calculation is looking for a file ending in
.sparsebundleCode: Select all
.backupbundle5) If you decide to modify the afp.conf file yourself it's recreated at every system restart and every restart of any of the file sharing services and over-writes the file removing any modifications you have made.
1) Modify
/sbin/svrcfg-alCode: Select all
vol size limit=kb2) Run a
cronCode: Select all
.backupbundleCode: Select all
ln -s file size.sparsebindle the-existing.backupbundleRe: Add quota for TimeMachine shared folder
Any update?
Any update on this please?
BTW, I'm a bit concerned BTRFS support is on the way-out with latest releases, while TimeMachine quota would benefit from it.
Or you would need to implement it with user quota, and let TimeMachine be of a specific user...
Please clarify your plans & timeline to finally support that feature.
