TOS 5 Beta is released for testing NOW!
christapor
Armenia
Re: TOS 5 Beta is released for testing NOW!
Post by christapor »
TMRyan wrote:
> Have you uninstalled your old TNAS PC? You can try uninstalling your old
> TNAS PC.
> If it doesn't work, you can try to open the firewall in the computer
> control panel, and then allow the TNAS PC to use the network.
> If the TNAS PC is not listed, you can click "allow other
> applications",then select the exe file of TNAS PC under the
> installation path.
Hello.
I tried all this things, and still, the TNAS PC app (v.5.04) stays stuck on the task bar !
Windows 10 x64 up to date.
Else, everything went well installing TOS 5. Even a TOS 5 upgrade today..
I just don't understand why this TNAS PC app doesn't open..
Dave11
Post by Dave11 »
[quote=christapor post_id=17246 time=1646947453 user_id=4854]
Hello.
[/quote]
I had the same issue the TNSA PC app just appears on the task bar and does nothing.
PS Looks like the mount point has changed for me from mnt/md0/ to Volume1/ so my Docker Jellyfin mount points were empty until I changed this.
e.g. -v /mnt/md0/Movies:/movies to -v /Volume1/Movies:/movies
Tricky
Post by Tricky »
I am running the updated original trial version of TOS5, and I am still getting the annoying addition to the user password when logging in, when will this be removed as it annoying, and I have no idea what the password is and I have no idea what it is?
I have resisted setting a new one in case it locks me out, also as the Beta version is out for all to test what happens when it officially released do we have to uninstall and reinstall the official version?
Charlie_Croker
Saudi Arabia
Post by Charlie_Croker »
Plex has now appeared in Applications
christapor
Armenia
> nothing.
I hope we soon gonna have a solution to this. It's not really easy to open the browser each time..
Kakise
Post by Kakise »
When can we expect an update for the Plex media server app ?
Charlie_Croker
Saudi Arabia
Kakise wrote:
It is already out and working on TOS5
Krunchy
Post by Krunchy »
So beyond what is stated in the "marketing speak" what does TRAID do exactly? Sounds like it could be a significant feature, but I can't find any information about it.
Charlie_Croker
Saudi Arabia
Krunchy wrote:
> New Flexible RAID Support in TRAID in TOS 5
Its like Synology Hybrid RAID https://kb.synology.com/en-uk/DSM/tutor ... d_RAID_SHR
"By optimizing the traditional RAID mode, TerraMaster RAID (TRAID) gives you flexible disk array configuration, flexible online migration, capacity expansion, and redundancy policies. As well as improving disk space utilization, it also provides solutions and security protection for storage space changes caused by new business requirements. Much like Synology Hybrid RAID (SHR) in that you can mix drive capacities for improved storage after the RAID redundancy calculation. "
Jac de Lad
Post by Jac de Lad »
That. That's an absolute killer feature and drives the value of TerraMaster NAS up. Very great!
