Hibernation not working?
Re: Hibernation not working?
After you configuring a RAID in a new TNAS device, data sync need to proccess backend in the system.
donsenilo
Post by donsenilo »
TMroy wrote: ↑06 Apr 2020, 21:24 After you configuring a RAID in a new TNAS device, data sync need to proccess backend in the system.
Ok, I get it. But my harddisks are now running more than 48 hours.
Terramaster F4-210
blur
Post by blur »
Could the issue be related to Btrfs, encrypted shared folders, or some other uncommon settings? Are there log files that show why the hard drives won't sleep?
If you created a EXT 4 file system, system will perform the block device journaling for the file system. This process may take several days which depend on the drive capacity.
blur
Post by blur »
I'm using 4 4TB disks with a btrfs file system in RAID 5 configuration.
The disks are still spinning after currently three days of uptime.
donsenilo
Post by donsenilo »
blur wrote: ↑10 Apr 2020, 19:50 I'm using 4 4TB disks with a btrfs file system in RAID 5 configuration.
Exactly (!) the same here.
Terramaster F4-210
if your drive indicators keep flashing every second, and you did not running any app, that means system works is in processing, please just wait for the job done.
blur
Post by blur »
The indicators are not flashing. All lights are constantly lit.
would you provide a screenshot for all your running processes from control panel> system information> resources monitor > process?
donsenilo
Post by donsenilo »
a screenshot is not possible, insert as text is not possible, pdf- and textfileattachment also.
here is the pdf-file as rar-file:
资源监控.rar
I really hope it helps because it was very complicated
Terramaster F4-210
