[ Tautulli ] Monitoring, analytics and notifications for PlexMedia Server
bradl822
Re: [ Tautulli ][ 2.9.7.0 ] Monitoring, analytics and notifications for PlexMedia Server
Post by bradl822 »
Just tried installing and got the following error.
<br />
<b>Warning</b>:  fopen(/mnt/appdata/MOD_CONFIG/Tautulli/logs/tautulli.log): failed to open stream: No such file or directory in <b>/usr/www/modules/Tautulli/www/6.php</b> on line <b>87</b><br />
I have both dependencies installed. Installed the latest version.
I couldn't find any issue. Does the WebUI says that Tautulli is running ?
Can you open the Configuration files menu and load the config ?
bradl822
Post by bradl822 »
We view opens and I keep clicking stay module which doesn't work. Keeps showing module stopped.
having only 2 lines in the config and missing the log file it means the app has never start.
Can you double check both dependencies are installed ? Python38 and ModBase1
Open the WebUI for both and check the installed version, eventually reinstall them
bradl822
Re: [ Tautulli ][ 2.10.0.0 ] Monitoring, analytics and notifications for PlexMedia Server
Post by bradl822 »
Thank you, you're correct. I had python installed through theterramaster TOS app store rather then your 3rd party version. All working now.
