f2-210 loosing internet connection
Re: f2-210 loosing internet connection
May I know what file system and what kind drive in your TNAS? we have learned from many cases, it probably not because of your network settings, instead, you are using a unhealthy hard drive. try to replace a drive and try again.
StogieC
Post by StogieC »
I have two identical F4-210 setups that are working great. The ping packet loss is what got my attention, and sustained writes to the drives work fine when I write from a USB drive connected directly to the unit. If this was a disk problem, writing from the USB would yield the same results as writing from the network.
StogieC wrote: 13 May 2021, 23:46
StogieC
Post by StogieC »
Screenshots of the drive type and file system here: viewtopic.php?f=23&t=1879&start=10#p10324
WD drives, btrfs. SMART tests and bad block scans all pass.
Well, another case about WD white lable drive. I am not sure if your case is related to this white lable drive, but we have bad experience about this kind of drives.
viewtopic.php?f=25&t=1271&p=6433&hilit= ... able#p6433
As I am not able to provide you a solution, I don't know what really happened to your device. if you can, try to remove your four drives, then install another drive(just one is good enough) , and reinstall TOS to verify if there is network settings ptoblem somewhere.
StogieC
Post by StogieC »
If you took the time to read these posts it is clear that this is not a hard drive issue... Can we focus on why the NIC is crashing on one of my three identically setup F4-210 systems?
Would you like a remote session from our engineer? To do that, you can write an email to our tech team.
sianderson
Post by sianderson »
TMroy wrote: 23 May 2021, 00:08 Well, another case about WD white lable drive. I am not sure if your case is related to this white lable drive, but we have bad experience about this kind of drives.
Please will you raise this to your higher managment at terramaster, 90% of all the issues that seem to be reported you claim its to do with the users hard drives that cause the units to crash, please will you consider putting in your own boot drives so that users hardrives are only ever data drives, therefore can not crash the nas unit if they are "not suitable" ones that are used, you will find once you do this you will have substantially less support issues and a happier user base of your products
F2-424 TOS 7.0.0765
F2-423 TOS 7.0.0765
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
{L_BUTTON_AT}sianderson
Thank you for your advice. I will pass it to the product team and tech guys.
Return to “Network”
