[ jDownloader ] download management tool
Hardfecx
Re: [ jDownloader ][2.00.02] download management tool
Post by Hardfecx »
With the help of the forum guys, i found how select only one server:
Settings > Plugins >*select the server*
brokenmass
Post by brokenmass »
@outkastm : is it possible to modify the plugin in such a way that jDownloader is not run as root user ?
Normally it can be done, need to test it
Roberbond
Post by Roberbond »
hi! thanks for the plugin.
I have installed it without problem, but I cannot set the download folder properly.
the default folder is: /root/Download but it doesn't work for me. It says: Skipped disk is full
I have created a shared folder in the root directory but it doesn't work either if I set to /Download
I can see this in myjdownloader:
How can I set the folder?
Roccia7
Italy
Post by Roccia7 »
Try with /mnt/Download
TNAS F2-220
TOS 5.0.176
Roberbond
Post by Roberbond »
it works! thanks! :D
Re: [ jDownloader ][2.00.03] download management tool
up to 2.00.03
Hardfecx
Post by Hardfecx »
Finally, the new version works fine with TOS 4.2.16. Thank you!
mikeromes
Post by mikeromes »
Thanks for this information. I haven't had problems with the new version also.
Pavulon
Post by Pavulon »
Hi.
Im new with terramaster and wondering about one thing :)
Question about download folder. Each file that has been downloaded is invisible in the folder. Jdownloader shows that the download is complete but when i open the folder...it is empty. When I download it again to the same folder, Jdownloader says that the one copy is already there. I dont know what the reason is. I would be grateful for any tips/help.
F2-210
