[ ResilioSync ][ 2.7.3.1381.0 ] Fast, reliable, and simple file sync and share solution
Roccia7
Italy
Re: [ ResilioSync ][ 2.7.3.1381.0 ] Fast, reliable, and simple file sync and share solution
Post by Roccia7 »
outkastm wrote: ↑26 Jul 2022, 04:01 added TOS5 version
Fantastic!! Thanks a lot!!! :D :D :D
TNAS F2-220
TOS 5.0.176
RedCraft
Post by RedCraft »
Hello, can you please make an ARM version? Ready to test
f2-210
corma
Italy
Post by corma »
RedCraft wrote: ↑07 Dec 2022, 17:23 Hello, can you please make an ARM version? Ready to test
can you please make an ARM version? :?: :D
dodgyroge
Post by dodgyroge »
Hi, I am running TOS 6.0.650 on a T12-423. I installed ResilioSync but when i try to run it, i just get this error :
(Access denied!) - you need to login on TOS with an admin role account.
I am currently logged in on an admin account and it still gives me the same errors. (pic attached)
Any help would be appreciated.
Wait for a TOS6 version of the app
dodgyroge
Post by dodgyroge »
Yes, I was wondering if that may help, but I have the exact same issue with Jellyfin (Jellyfin TOS6 10.10.5.0 x86_64.tpk).
I have figured out a work-around, if this helps anyone else......
What I did with Jellyfin was to use the web interface, putting the IP address of my TNAS, followed by the port number of that app (listed under Control Panel/System Info/Port). This has allowed me to access Jellyfin on my TNAS, but without trying to access the app from the TNAS desktop - which doesn't seem to work anyway.
So I have just tried this with ResilioSync, and it works fine.
KKI
Sweden
Post by KKI »
Hi :)
Does this work on?
Model
F2-212
TOS version
5.1.73-00078
