[ Nextcloud ] Self-hosted productivity platform
sanctimon
Re: [ Nextcloud ][ 23.0.0.0 ] Self-hosted productivity platform
Post by sanctimon »
Thank you,
I have now removed the TOS version - no need for 2 databases on a machine with limited CPU capacity and have installed your version.
Your version of Nextcloud also works quite well; just a side note: I did change the data location during installation to another volume (my RAID volume, designed specifically for backup). I found it was necessary to change the owner for that directory for the setup to work to www-data:www-data, but that was easy and worked like a charm.
I am still having an issue with file integrity - there are a lot of files in there that fail integrity scan.
See here: https://pastebin.com/KjHkG3Yb
Could there be some corruption in your tkp installation file?
sanctimon
Post by sanctimon »
I have managed to install Nextcloud successfully and get rid of the integrity scan issues by not installing the "additional apps" such as mail, etc.
I was able to download some that I needed to download as an extra.
Very disappointed at some of the bugs that seem to be plaguing iOS and other mobile Nextcloud apps at the moment - takes a lot of troubleshooting to get them set up.
There is also a curious warning in the log:
Module 'sodium' already loaded at Unknown#0
Have you encountered this before?
Sodium is now embedded in the php itself, you have to disable loading the extension.
From nextcloud webconfig go to Configuration files >> edit php.ini and disable sodium.so
sanctimon
Post by sanctimon »
Thank you, this should do the trick.
Hardfecx
Post by Hardfecx »
is it possible to get an ARM version?
Re: [ Nextcloud ][ 23.0.0.1 ] Self-hosted productivity platform
up to 23.0.0.1
sanctimon
Post by sanctimon »
Can we simply apply the upgrade over the existing installation?
sanctimon
Post by sanctimon »
Hello again, I would like to continue the discussion found here viewtopic.php?f=37&t=1588&start=22, as it is a more appropriate thread.
The initial cron set up that I had managed to make work has stopped working for some reason. I am getting the below message (attached).
I accessed crontab and it looks like my line had been removed.
I then proceeded to try out your solution as above.
I entered:
sudo crontab -u www-data -e
and inserted the line you recommend:
*/5 * * * * www-data /usr/local/bin/Nextcloud_okm cron.php
I am afraid that the below error remains, even though the job is supposed to run every 5 minutes. I did restart Nextcloud.
Any advice?
I recommend you to use Cron_okm app for your personal jobs and not the crontab from TOS. This way you are sure your jobs are not removed in case of TOS update, reboot etc
