F2-221: multiple errors initializing
Re: F2-221: multiple errors initializing
You should remove HDD1 when TNAS is off, insert the hard drive, and then turn it on. You can go to the control panel to check the hard drive status. You can try a few more times to make sure it is not because the hard disk is not plugged in properly.
apinheiro
Post by apinheiro »
Many thanks. It was indeed a problem with the HDD. It has been now sent to warranty.
Best regards and much appreciation for all the help provided.
Return to “Initialization”
