Transfer rates copying files to NAS are slow and sporadic
Re: Transfer rates copying files to NAS are slow and sporadic
So you guys recommend using the ext4 file system for your NAS boxes instead of the btrfs. I thought the btrfs was recommended for stability and snapshot backups? Can you please explain this more? Also should I then downgrade my TOS from 4.10 to 4.09 in order to see speed improvements? That seems kind of backwards. Are the improvements not already built in to the 4.10 beta?
TMS
ext4 and btrfs have their own merits, and the TOS transmission speed of 4.2.10Beta version is no problem (any problem?).
- sianderson
- Silver Member
sorry to just jump in here which is meant to provide the faster transfer speed EXT4 or BTRFS?
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
There is no way for me to switch to the ext4 file system from btrfs for my RAID5 is there without losing all of my current data?
- firedrakes
idk but my speed even slower now. sub 11mb. i used to get 100mb on a gb netowrk. then a week or 2 ago it went to 11mb and now sub 11mb.
idk what to do to fix this issue. i follow and all check list to narrow it down. it seems to be a os issue with tnas.
TMS
1.Where are you transferring files to TNAS?
2. What is the TOS version and device model?
3. Do you check Control Panel》 LAN displays 1000MB/s?
- firedrakes
4.2.08
f4-210
yes it display 1000MB
f4-210
TMS
Is it possible to let our engineer check it remotely?
Please follow this link:viewtopic.php?f=75&t=608
- firedrakes
sure. when a good day and time.. i live in east usa
Maybe you would take a look at tools like Carbonite or Gs Richcopy 360, both have high performance, simple, and very quick copying to NAS.
Also, you will have the advantage to control the bandwidth while copying to NAS, try the trial versions first to ensure that any of both meets the requirements
