[Help] TOS7 Apps Data Location Behaviour - Possible Bug
Re: [Help] TOS7 Apps Data Location Behaviour - Possible Bug
Here's another approach that may help.
Before installing Emby from the App Center, make sure to click the Refresh button (see screenshot below).
digi999
Post by digi999 »
Thankyou again for taking the time to investigate. I'll give Terramaster credit they really do take on board and try to investigate these issues! For me (after a lot of testing), I finally managed to get Emby working correctly on my F6-424 with TOS 7.
In the end, the solution was:
Completely uninstall Emby.
Delete all old Emby data (/Volume1/Emby, any old -ffdetect data, cache files, etc.) so there was no previous configuration left.
Install the latest TerraMaster-compatible Emby package (v4.9.5.0) downloaded directly from the Emby website rather than the older App Center version.
Initially, Emby still had problems after reboot because the launcher wasn't passing a valid ProgramData directory, causing Emby to create its database in the wrong location.
I modified the launcher script to explicitly set:
APP_DATA_DIR="/Volume2/Emby"
instead of dynamically calling:
APP_DATA_DIR=$(ter_share_add -name "Emby")
After that, Emby started correctly with:
-programdata /Volume2/Emby
and now stores all of its:
database
metadata
artwork
cache
plugins
logs
under:
/Volume2/Emby
which is exactly what I wanted, as my applications are installed on an NVMe storage pool.
I've now rebooted the NAS several times and Emby continues to start normally every time.
Important note for TM Firmware Team:
Although this workaround has completely solved the problem for me, I believe there is still an underlying issue with the package or launcher. It would be useful if the launcher handled a failure of ter_share_add more gracefully rather than starting Emby without a valid ProgramData path.
We will be publishing an updated Emby application in the App Center in the near future. This new version will support the directory modification method described above.
TMzethar wrote: ↑12 Jul 2026, 09:28 Uninstall Emby app, delete the shared folder named “Emby,” and reinstall Emby app on Volume 2.
When you re-enable Emby, it should automatically create the Emby-specific shared folder on Volume 2.
Argonautica
New Zealand
Post by Argonautica »
I am also looking forward to the updated Emby application version. I'm glad I trawled the forums before installing Emby from the App Centre, as it sounds like there are a number of issues. This particular one (installing to a separate SSD Volume for speed) would have affected me in exactly the same way as described by digi999. Thanks for getting to the bottom of it!
