Big Sur
lucasprbanking
Re: Big Sur
Post by lucasprbanking »
You’re a legend. Thanks for posting the new driver here. I just installed the driver but haven’t started testing the D5 yet. Has it been working well for you? Thanks again for posting the driver here
daily2500
Re: Big Sur
Post by daily2500 »
No probs! I've installed the new drivers on an iMac 2019 since yesterday and the array has been rebuilding and not continuously failing like it used to. The D5's array has reached 8% now, about 1-4% of progress each day. It also doesn't have the icon anymore saying one of the drives has an error which the old driver did, even though there was nothing wrong.
Will keep everyone posted on how it goes.
lucasprbanking
Re: Big Sur
Yeah, sounds accurate for 70tb. My array is 50tb (40tb usable in raid 5) and the rebuild took 30 hours once I rolled the MacBook to Catalina. I actually returned the MacBook yesterday and only have iMac Pro running Big Sur left so I’m hoping the new driver is stable. Once my rebuild finished, the raid was stable in Catalina for a day or two so this sounds promising since your hasn’t been failing the rebuild since the new drivers were installed. Thanks again, I will update once I get to test the raid in Big Sur with the new drivers.
dabuchho
Re: Big Sur
Post by dabuchho »
Have tried these latest drivers with my D5 on my Mac Mini Late 2018 and it works for about 6-8 hours before it completely shuts down again with a critical failure state. This is after the rebuild had completed. Would be interested to see if anyone else has completed rebuild and seen the same issues? Before these drivers it would fail in 45-60 minutes, so it is longer but having the same issue.
lucasprbanking
Re: Big Sur
Damn, that is terrible news. I’ve installed the new drivers and have made a few test transfers (1.5tbs of fcpx projects) and so far no issues here. However, I’ve been ejecting the D5 after the transfers are complete since I’m still nervous about another failure. Sounds like I’ll just have to wait around for a solid fix. Quite unfortunate since this system sure isn’t cheap and should have better support than we’re experiencing.
Re: Big Sur
The TerraMaster official new driver has not been released yet.
daily2500
Re: Big Sur
Post by daily2500 »
dabuchho wrote: ↑22 Nov 2020, 01:20 Have tried these latest drivers with my D5 on my Mac Mini Late 2018 and it works for about 6-8 hours before it completely shuts down again with a critical failure state. This is after the rebuild had completed. Would be interested to see if anyone else has completed rebuild and seen the same issues? Before these drivers it would fail in 45-60 minutes, so it is longer but having the same issue.
Since the 19th November the array has been rebuilding the 70TB drive and it's at 52%. Will wait until it's done to further stress test the D5.
lucasprbanking
Re: Big Sur
daily2500 wrote: ↑25 Nov 2020, 18:58
I can't believe your array is still rebuilding. Here is an update from my experience with the new drivers:
I have had no errors or failures since installing the new drivers. However, I have been ejecting the D5 when not in active use. It's is a work drive so I can't afford to have to rebuild it again. Would be interesting to see how other's are coping with these issues.
daily2500
Re: Big Sur
Post by daily2500 »
After 15 days of rebuilding the array it has been completed successfully and the drive is operating as normal. Thnak you to the Highpoint team to release a successful driver so quickly and successfully!
