golgoth
Italy
Post by golgoth »
This is also the reason, i suppose, that makes qbittorrent unstable. Every transfer process, even to external HD, saturates the CPU.
Ohlssons
Germany
Post by Ohlssons »
Hopefully new version coming soon...
F4-423 |TOS 6.0436 | 4 x 8 TB HDD | 2 x 1 TB NVME | 32 GB RAM
golgoth wrote: ↑12 Aug 2024, 14:19
Ohlssons wrote: ↑12 Aug 2024, 13:25
You can observe the system resource usage of each process in TOS > Control Panel > Process.
golgoth
Italy
Post by golgoth »
TMzethar wrote: ↑12 Aug 2024, 16:30 You can observe the system resource usage of each process in TOS > Control Panel > Process.
So what? Is this a known issue and will it be fixed soon?
golgoth wrote: ↑12 Aug 2024, 17:00
Based on your limited description and speculation, we are unable to confirm the problem. We recommend contacting the customer service window on the website or the technical support e-mail address to make an appointment for an engineer to check the problem remotely for you. (Please tell this post.)
Ohlssons
Germany
Post by Ohlssons »
So, there are the processes during copy-task; I can't identify a process, that needs nearly 70 % of CPU...
Ohlssons wrote: ↑12 Aug 2024, 23:21
From where did you see that the cp process is occupying 77% of the CPU? The process clearly shows 6.05%. The 77% figure represents the device load, not CPU usage. Device load is related to CPU usage, disk I/O, network I/O, and memory usage.
Please check which process is occupying your CPU resources.
Lex
Post by Lex »
TMroy wrote: ↑09 Aug 2024, 12:35 Could you please describe your operational steps in detail?
I update TOS 6.(240).
After update and reboot, the system prompted for a new username.
I input username, password. But I need input email.
New system can`t send mail for check address. Input user form have link for skip email check.
I press some times this link, than press back and input new user name, press link for skip email check...
After I refresh page in firefox.
And I see login screen.
TMroy wrote: ↑09 Aug 2024, 12:35 You update system from which version to which version?
TMroy wrote: ↑09 Aug 2024, 12:35 After update, the web page asked you to setup a new password and username to the superuser, right?
yes
TMroy wrote: ↑09 Aug 2024, 12:35 You did it, and you pressed button to send verification code, but it fails to send, right?
yes
TMroy wrote: ↑09 Aug 2024, 12:35 after that, you pressed "Skip" button, and then?
yes. Press some times, no result. Press back, input new user name, press skip...
TMroy wrote: ↑09 Aug 2024, 12:35 what did you mean 'It request update page'?
Refresh page in browser. Sorry.
F4-423
imranalam
Pakistan
Post by imranalam »
imranalam wrote: ↑04 Aug 2024, 21:10
After updating to 6.0.436 version , now TNAS.online works perfect.
Thanks for update and resolving issues.
