[ Jellyfin ] The Free Software Media System
Re: [ Jellyfin ] The Free Software Media System
Has anyone managed to set up hardware encoding on the f4-424 pro? Doesn't work for me, iHD driver is installed.
F4-424 MAX TOS 7
Check the Jellyfin logfiles for some info.
And did you configured HW transcoding in Jellyfin ?
Hi, yes.
Log jellyfin + ffmpeg --hwaccels + sreenshots attached.
./ffmpeg -init_hw_device vaapi=va:,kernel_driver=i915,driver=iHD
Device creation failed: -542398533.
Failed to set value 'vaapi=va:,kernel_driver=i915,driver=iHD' for option 'init_hw_device': Generic error in an external library
Error parsing global options: Generic error in an external library
./ffmpeg -init_hw_device qsv=qs@va
Invalid device specification "qsv=qs@va": invalid source device name
Failed to set value 'qsv=qs@va' for option 'init_hw_device': Invalid argument
Error parsing global options: Invalid argument
[samius@TNAS_Sam bin]# ./ffmpeg -hwaccels
ffmpeg version 5.1.3 Copyright (c) 2000-2022 the FFmpeg developers
built with gcc 7.2.0 (Buildroot 2017.11.2)
configuration: --pkg-config=pkg-config --prefix=/usr/local/ffmpeg51/sys --arch=x86_64 --target-os=linux --cross-prefix=x86_64-tnas-linux-gnu- --enable-cross-compile --extra-cflags='-O2 -I/usr/local/ffmpeg/sys/include' --extra-ldflags=-L/usr/local/ffmpeg/sys/lib --enable-static --enable-gpl --enable-version3 --libdir=/usr/local/ffmpeg51/sys/lib --shlibdir=/usr/local/ffmpeg51/sys/lib --enable-libcelt --enable-fontconfig --enable-gnutls --enable-hwaccels --enable-vaapi --enable-iconv --enable-libass --enable-libbluray --enable-libdc1394 --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-librtmp --enable-libxvid --enable-libmodplug --enable-libopus --enable-shared --enable-pthreads --enable-libopenjpeg --disable-libopencv --enable-avisynth --enable-libgme --enable-libcaca --enable-libx264 --enable-libx265 --disable-doc --disable-htmlpages --disable-manpages --disable-podpages --disable-txtpages --extra-libs=-latomic --cpu=nocona --enable-libdrm --enable-libmfx --enable-libvpx
libavutil 57. 28.100 / 57. 28.100
libavcodec 59. 37.100 / 59. 37.100
libavformat 59. 27.100 / 59. 27.100
libavdevice 59. 7.100 / 59. 7.100
libavfilter 8. 44.100 / 8. 44.100
libswscale 6. 7.100 / 6. 7.100
libswresample 4. 7.100 / 4. 7.100
libpostproc 56. 6.100 / 56. 6.100
Hardware acceleration methods:
vaapi
qsv
drm
Devices:
D. = Demuxing supported
.E = Muxing supported
DE alsa ALSA audio output
E caca caca (color ASCII art) output device
DE fbdev Linux framebuffer
D kmsgrab KMS screen capture
D lavfi Libavfilter virtual input device
D libdc1394 dc1394 v.2 A/V grab
DE oss OSS (Open Sound System) playback
DE video4linux2,v4l2 Video4Linux2 output device
[2024-05-10 12:27:42.913 +03:00] [INF] [39] Jellyfin.Api.Helpers.MediaInfoHelper: User policy for "samius". EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
[2024-05-10 12:27:42.914 +03:00] [INF] [39] Jellyfin.Api.Helpers.MediaInfoHelper: StreamBuilder.BuildVideoItem( Profile="Anonymous Profile", Path="/Volume4/Media/Фильмы/Подземелья и драконы Честь среди воров 2023г.mkv", AudioStreamIndex=1, SubtitleStreamIndex=9 ) => ( PlayMethod=Transcode, TranscodeReason=VideoCodecNotSupported, AudioCodecNotSupported ) "media:/videos/6718348f-a89b-70e0-4147-ecaac7233b6d/master.m3u8?MediaSourceId=6718348fa89b70e04147ecaac7233b6d&VideoCodec=h264&AudioCodec=aac,mp3&AudioStreamIndex=1&VideoBitrate=139616000&AudioBitrate=384000&MaxFramerate=23.976025&api_key=<token>&TranscodingMaxAudioChannels=2&RequireAvc=false&Tag=16f9044aab4a377c2ab7d2f20742a635&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&hevc-level=150&hevc-videobitdepth=10&hevc-profile=main10&TranscodeReasons=VideoCodecNotSupported,%20AudioCodecNotSupported"
[2024-05-10 12:27:43.308 +03:00] [INF] [41] Jellyfin.Api.Controllers.DynamicHlsController: Current HLS implementation doesn't support non-keyframe breaks but one is requested, ignoring that request
[2024-05-10 12:27:43.309 +03:00] [INF] [41] Jellyfin.Api.Helpers.TranscodingJobHelper: "/usr/local/ffmpeg51/sys/bin/ffmpeg" "-analyzeduration 200M -init_hw_device vaapi=va:,kernel_driver=i915,driver=iHD -init_hw_device qsv=qs@va -filter_hw_device qs -autorotate 0 -i file:\"/Volume4/Media/Фильмы/Подземелья и драконы Честь среди воров 2023г.mkv\" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -preset 7 -look_ahead 0 -b:v 49986168 -maxrate 49986168 -bufsize 99972336 -g:v:0 72 -keyint_min:v:0 72 -vf \"setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale=trunc(min(max(iw\,ih*a)\,min(3840\,1608*a))/2)*2:trunc(min(max(iw/a\,ih)\,min(3840/a\,1608))/2)*2,format=yuv420p\" -codec:a:0 aac -ac 2 -ab 384000 -af \"volume=2\" -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type mpegts -start_number 0 -hls_segment_filename \"/usr/local/@APP_CONFIG/Jellyfin/data/transcodes/0a4136ab31c19a9729f67c17023f0903%d.ts\" -hls_playlist_type vod -hls_list_size 0 -y \"/usr/local/@APP_CONFIG/Jellyfin/data/transcodes/0a4136ab31c19a9729f67c17023f0903.m3u8\""
[2024-05-10 12:27:43.328 +03:00] [ERR] [45] Jellyfin.Api.Helpers.TranscodingJobHelper: FFmpeg exited with code 1
[2024-05-10 12:27:43.427 +03:00] [ERR] [39] Jellyfin.Server.Middleware.ExceptionMiddleware: Error processing request. URL "GET" "/videos/6718348f-a89b-70e0-4147-ecaac7233b6d/hls1/main/0.ts".
MediaBrowser.Common.FfmpegException: FFmpeg exited with code 1
at Jellyfin.Api.Helpers.TranscodingJobHelper.StartFfMpeg(StreamState state, String outputPath, String commandLineArguments, HttpRequest request, TranscodingJobType transcodingJobType, CancellationTokenSource cancellationTokenSource, String workingDirectory)
at Jellyfin.Api.Controllers.DynamicHlsController.GetDynamicSegment(StreamingRequestDto streamingRequest, Int32 segmentId)
at Jellyfin.Api.Controllers.DynamicHlsController.GetHlsVideoSegment(Guid itemId, String playlistId, Int32 segmentId, String container, Int64 runtimeTicks, Int64 actualSegmentLengthTicks, Nullable`1 static, String params, String tag, String deviceProfileId, String playSessionId, String segmentContainer, Nullable`1 segmentLength, Nullable`1 minSegments, String mediaSourceId, String deviceId, String audioCodec, Nullable`1 enableAutoStreamCopy, Nullable`1 allowVideoStreamCopy, Nullable`1 allowAudioStreamCopy, Nullable`1 breakOnNonKeyFrames, Nullable`1 audioSampleRate, Nullable`1 maxAudioBitDepth, Nullable`1 audioBitRate, Nullable`1 audioChannels, Nullable`1 maxAudioChannels, String profile, String level, Nullable`1 framerate, Nullable`1 maxFramerate, Nullable`1 copyTimestamps, Nullable`1 startTimeTicks, Nullable`1 width, Nullable`1 height, Nullable`1 maxWidth, Nullable`1 maxHeight, Nullable`1 videoBitRate, Nullable`1 subtitleStreamIndex, Nullable`1 subtitleMethod, Nullable`1 maxRefFrames, Nullable`1 maxVideoBitDepth, Nullable`1 requireAvc, Nullable`1 deInterlace, Nullable`1 requireNonAnamorphic, Nullable`1 transcodingMaxAudioChannels, Nullable`1 cpuCoreLimit, String liveStreamId, Nullable`1 enableMpegtsM2TsMode, String videoCodec, String subtitleCodec, String transcodeReasons, Nullable`1 audioStreamIndex, Nullable`1 videoStreamIndex, Nullable`1 context, Dictionary`2 streamOptions)
at lambda_method1068(Closure , Object )
at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.TaskOfActionResultExecutor.Execute(IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeActionMethodAsync>g__Awaited|12_0(ControllerActionInvoker invoker, ValueTask`1 actionResultValueTask)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeNextActionFilterAsync>g__Awaited|10_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Rethrow(ActionExecutedContextSealed context)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeInnerFilterAsync>g__Awaited|13_0(ControllerActionInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeNextResourceFilter>g__Awaited|25_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Rethrow(ResourceExecutedContextSealed context)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeFilterPipelineAsync>g__Awaited|20_0(ResourceInvoker invoker, Task lastTask, State next, Scope scope, Object state, Boolean isCompleted)
at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
at Microsoft.AspNetCore.Routing.EndpointMiddleware.<Invoke>g__AwaitRequestTask|6_0(Endpoint endpoint, Task requestTask, ILogger logger)
at Jellyfin.Server.Middleware.ServerStartupMessageMiddleware.Invoke(HttpContext httpContext, IServerApplicationHost serverApplicationHost, ILocalizationManager localizationManager)
at Jellyfin.Server.Middleware.WebSocketHandlerMiddleware.Invoke(HttpContext httpContext, IWebSocketManager webSocketManager)
at Jellyfin.Server.Middleware.IpBasedAccessValidationMiddleware.Invoke(HttpContext httpContext, INetworkManager networkManager)
at Jellyfin.Server.Middleware.LanFilteringMiddleware.Invoke(HttpContext httpContext, INetworkManager networkManager, IServerConfigurationManager serverConfigurationManager)
at Microsoft.AspNetCore.Authorization.Policy.AuthorizationMiddlewareResultHandler.HandleAsync(RequestDelegate next, HttpContext context, AuthorizationPolicy policy, PolicyAuthorizationResult authorizeResult)
at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
at Jellyfin.Server.Middleware.QueryStringDecodingMiddleware.Invoke(HttpContext httpContext)
at Swashbuckle.AspNetCore.ReDoc.ReDocMiddleware.Invoke(HttpContext httpContext)
at Swashbuckle.AspNetCore.SwaggerUI.SwaggerUIMiddleware.Invoke(HttpContext httpContext)
at Swashbuckle.AspNetCore.Swagger.SwaggerMiddleware.Invoke(HttpContext httpContext, ISwaggerProvider swaggerProvider)
at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
at Jellyfin.Server.Middleware.RobotsRedirectionMiddleware.Invoke(HttpContext httpContext)
at Jellyfin.Server.Middleware.LegacyEmbyRouteRewriteMiddleware.Invoke(HttpContext httpContext)
at Microsoft.AspNetCore.ResponseCompression.ResponseCompressionMiddleware.InvokeCore(HttpContext context)
at Jellyfin.Server.Middleware.ResponseTimeMiddleware.Invoke(HttpContext context, IServerConfigurationManager serverConfigurationManager)
at Jellyfin.Server.Middleware.ExceptionMiddleware.Invoke(HttpContext context)
F4-424 MAX TOS 7
./ffmpeg -v verbose -init_hw_device vaapi=va:,kernel_driver=i915,driver=iHD -init_hw_device qsv=qs@va
[AVHWDeviceContext @ 0x1a7d180] Cannot open DRM render node for device 0.
[AVHWDeviceContext @ 0x1a7d180] Cannot open a VA display from DRM device (null).
./vainfo
error: failed to initialize display
Aborted
./vainfo
Aborted
F4-424 MAX TOS 7
and the result of the command ?
dmesg | grep i915Re: [ Jellyfin ] The Free Software Media System
Nothing
# dmesg | grep i915
F4-424 MAX TOS 7
Try a reboot and run the command again. This should return some info if the kernel has loaded correctly the GPU. If still no message, you can maybe check with TM. Hopefully there is no need for a new kernel.
