TOS 5 Beta is released for testing NOW!
Re: TOS 5 Beta is released for testing NOW!
We will release the tool when it is ready.
krisprolls
Post by krisprolls »
Installed last version and still having issue of logging through the web, my SIMPLE name and password doesn't work after a reboot of TNAS. It is really boring as I cannot test the TOS 5.
It works through AFP, SSH, SMB with the same password so please try to fix this up before the rest, it is really annoying.
I might have installed over 20 times TOS, used different passwords each time.
regards
{L_BUTTON_AT}krisprolls
If convenient, you can contact our tech team to have a check.
Charlie_Croker
Saudi Arabia
Post by Charlie_Croker »
> time.
> regards
Make sure you dont use any special characters, for some reason TOS5.0 can't handle those in a password).
I get similar, though I can usually log in for a few days before I lose access, (But can still access via SMB/AFP).
MisterXY
Germany
Post by MisterXY »
Is this special characters on a english keyboad layout?
{L_BUTTON_AT}Charlie_Croker
would you tell me which special character you used in your password? we will verify it.
MisterXY
Germany
Post by MisterXY »
Is it possible for the beta version to synchronize the Linux system to all hard drives? If I set up the system on my SSD and install everything under /opt via entware, then remove the SSD and connect it via internal USB, then the system has the same point of view as when it was removed. Once the SSD is attached to the internal port, nothing is saved. Any changes will not be saved.
Either everything was synchronized internally and nothing is saved anymore, or the internal connection only has a kind of read-only mode where nothing is saved anymore.
Furthermore, the mount point is very strange. Everything is mounted under /Volume1,2,3 etc. and no longer under /mnt/md0,1,2 and as soon as a new disk is mounted, the volume points change again. What was /Volume1 before may now be /Volume2. That's solved very strange.
Charlie_Croker
Saudi Arabia
After another issue (Bug report submitted) I have decided to revert back to TOS 4.
I am spending far too much time reinstalling TOS5.0 due to various issues. I will try it again when it is in Release Candidate.
krisprolls
@ charlie
I do not use any special character, simple letters.
The issue is it works on afp, smb, but no more on http every time.
I can access my terra master through these, but cannot test the system through http.
I have a F420 on Mac OS 12.4
Can't access through windows, iPad, iPhone.
Will wait for a final release tired of installing the system
Charlie_Croker
Saudi Arabia
@TMRoy
TNAS PC (Mac version TOS5.0)
I have reported (via email) a bug report stating that TNAS PC doesn't work with MacOS Monterey 12.5 onwards. Can you please let us know when a working version will be supplied?
Also will we ever get working versions of the app for Android and iOS?
