The Brand New TOS 5 is Released!
- OllieHardy
Re: The Brand New TOS 5 Officially Released Today!
TOS has now been updated to 5.0.124 however TNAS PC still cannot find it...... woeful
- rocketron51
@OllieHardy
I think you will also find TNAS PC has been updated to 5.0.24
- OllieHardy
rocketron51 wrote:
Thanks . I can't find a link for that, do you know how I can find and install this please
- rocketron51
@OllieHardy
At the moment there is no link to download TNAS PC 5.0.24
I opened TNAS PC 5.0.23 and it said there was an update so I let it update to 5.0.24, but it doesn't appear to be any different.
- OllieHardy
Thank you. I have redownload the TNAS pc and disabled my firewall and unfortunately it's still not finding the NAS 🤣
- rocketron51
@ OllieHardy
This is how stupid Terramaster are:-
On 1 computer I am running TNAS PC V5.0.25 and if you go into settings it says this is the current version
On another computer I am running TNAS PC V5.0.23 and if you go into settings it says this is current version
Both PC's are running Windows 10 Pro 21H2
how crazy is that
how crazy is that
- OllieHardy
Yep,
Mine also says it is running the current version in blue text, and the link is not clickable to check for more firmware updates. Really very annoying. They shouldn't have rolled this out in its current state
jonwren wrote:
> Still can't update Plex
> still stuck on 1.24
> lastest version 1.27
You can download Plex Media Server v1.27 for Terramaster direct from Plex and install manually. https://www.plex.tv/media-server-downloads/
However be aware that the Apps section of TerraMaster TOS sees a different version available and thinks its an update, however clicking on the update installs v1.24 from TerraMaster and rolls back the version.
Now when I uninstall and reinstall using the v1.27 of Plex the NAS still says it is v1.24.
> still stuck on 1.24
Is it possible to install the plex from official Plex site on TOS5?
If not, here is the link to the latest version 1.27.1.5916 for TOS5
https://bit.ly/39VGKBQ
SO I'm not an admin here but i know why this is not working - the mapping for the files to install is incorrect the old path was /md0/mnt and the new path is /Volume1. So the Plex TPK is using a install method that points to a disk that is not currently on the system - so the that is why we are getting the error "Incorrect Package" Your Link is helpful but the Plex Coders will have to adjust the paths to patch the new layout.
The path is the only thing that i found that has really changed on us here.
