Public Beta Testing for TOS 6 ARM Version
crisisacting
Re: Public Beta Testing for TOS 6 ARM Version
Post by crisisacting »
sergokaban wrote: ↑13 Apr 2026, 18:38 No Docker? Seriously? This update sucks.
TOS 7 ARM beta has an Ubuntu base, so technically, you should be able to install docker on your own (versus having an app from TerraMaster or a TNAScommunity app) via terminal.
This guide might/should suffice to for so: https://www.digitalocean.com/community/ ... untu-22-04
GPU support is possibly not there, so images requiring that might not function.
sergokaban
Post by sergokaban »
Has anyone succeeded in this?
gooeynick0t
Post by gooeynick0t »
sergokaban wrote: ↑18 Apr 2026, 16:49 Has anyone succeeded in this?
yes. basically you need to follow the official docker installation instructions for ubuntu with a few caveats. https://docs.docker.com/engine/install/ubuntu/
1) there's no /etc/os-release, so docker can't find out what OS you're running. fixed by adding a stub /etc/os-release pointing to ubuntu 22.04 (I believe TOS6 is based on it)
# cat /etc/os-release
PRETTY_NAME="Ubuntu 22.04.4 LTS"
NAME="Ubuntu"
VERSION_ID="22.04"
VERSION="22.04.4 LTS (Jammy Jellyfish)"
VERSION_CODENAME=jammy
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=jammy
2) I moved data-root (where docker stores oci images) to a volume, instead of the default root, since root is very storage constrained
# cat /etc/docker/daemon.json
  "data-root": "/Volume1/.docker_data"
3) for some reason when the nas reboots it cannot find said data-root mentioned above. fixed by restarting the systemd daemon via cron
@reboot systemctl restart docker
edit to add: this was all done on TOS6. not sure how it will play out on TOS7. haven't bothered to test it out yet
