TOS 6.0.530 Official Version Released
GustuvWynd
Re: TOS 6.0.530 Official Version Released
Post by GustuvWynd »
TMRyan wrote: 06 Dec 2024, 18:36 We would like to know some information: What is the capacity of the volume and the cache disk you selected when creating the Hyper Cache?
Could you provide us with a screenshot?
How much available memory did you have when you created it?
The Volume size is 54TB and the SSD is 4TB.
Some new information:
The 54TB volume was created on TOS5. I plugged in a simple USB DAS and created a new volume that was 67TB in size, but made under TOS 6. I was able to setup the same 4TB SSD as hyper cache for without issue. I can remove it and add it with no issue as well. So this could be something related to migrating from TOS 5 to TOS 6.
Attaching images appear to be blocked for me, but everything looks good until that error message after I select the Confirm button. This is just a home lab where I am testing out the U4-432 for a possibility of a larger deployment. So there would be no issue if an engineer or developer wanted to look at it. I did generate and send a report package on it yesterday.
agarza647
Post by agarza647 »
Gremlin wrote: 04 Nov 2024, 22:26 Prepared new Tos5 legacy uefi usb flash drive.
Are there instructions somewhere on how to do this?
agarza647 wrote: 07 Dec 2024, 08:50
Yes, of course.
Try this thread. Suitable ibnitboot images can be downloaded from links in first post on this thread. (Depends on your model. Choose carefiully.)
You can refer to this: viewtopic.php?t=6433
Sorry, link didn't get inserted. Tks @TMRyan
eulero
Italy
Post by eulero »
Trying to do the update and as usual ..... a fail .....
here my actual configuration:
After the update loading, the update start and after 40% it fail with this message:
Please, tell me how to update.
AM
Current System:
F2-422 - 4TB storage
TOS- 7.0.0333
eulero wrote: 21 Dec 2024, 19:28
I don't think you can update that way (direct from 5.1.145) since the -422 models are, as far as I know, not yet on the "approved" update list.
UNTIL TERRA-MASTER SORT OUT THE UPDATE PROCESS FOR ALL OUTSTANDING MODELS we are stuck waiting.
eulero
Italy
Post by eulero »
Thank you ... the Beta was misleading because released also for 422.
I'll wait, see you bud and thanks again.
AM
Current System:
TOS- 7.0.0333
jwills70
Post by jwills70 »
I am using tos 6.0.555
T9-450
I am having problems in that I have a terramaster usb 5 disk enclosure attached
Everytime I shut down and reboot it does not remember the previous assigned letters for the usb disks this is causing major issues as I use it for plex and I have to repoint the drive letters in plex everytime it reboots
It worked fine in tos 5
ckellawan
Post by ckellawan »
Just upgraded to 6.055 on an F4-223. So far so good, everything is running well.
