thierrys73
France
Post by thierrys73 »
Tnas T6-423
Tnas F2-221
fcs001fcs
Post by fcs001fcs »
Alex281 wrote: ↑07 Aug 2024, 02:05
Alex281 wrote: ↑07 Aug 2024, 01:31
fcs001fcs wrote: ↑07 Aug 2024, 00:18 Is the Bonding using the 802.3ad protocol working on the F4-423 with TOS 6.0.420 Beta?
I also lose all connectivity when attempting to bond with 802.11ad. F4-424. Switch is Unifi USW-16-poe on newest EA firmware.
Updated to 6.0.436 and LACP seems to be working now.
@Alex281
Thanks a lot for the info. Updated to 6.0.436 and LACP is now working as it should. I have a good Bond of the two NAS LAN ports and I confirmed they survive a reboot and shutdown/restart.
F4-423 - 2 x12TB & 1x14TB & 1x16TB - BTRFS TRAID
terraNASty
St Helena
Post by terraNASty »
fcs001fcs wrote: ↑07 Aug 2024, 05:21
@Alex281
I am also having major connection issues with bonding on my system running 420. Please tell me how you received 436 so that I can fix my connection.
Thank you!
terraNASty
St Helena
OK, when I am able to keep the NAS up long enough, it now sees the 436 update but continually loses connection to the switch to where I cannot actually get anything done without restarting via the power button and then trying again before it loses connection again. Will update for the sake of others if I manage to find a workaround.
DCCentR
Post by DCCentR »
DCCentR wrote: ↑22 Jul 2024, 20:41
TMRyan wrote: ↑22 Jul 2024, 18:33
DCCentR wrote: ↑22 Jul 2024, 17:49
This update uses a completely new root filesystem and most features have been changed, so there is no update log. Thanks for your feedback, you can try to re-open the app Center and enable Docker Engine.
Docker Engine started after restarting the App center, thanks!
Found this bug, I have one NVME installed in the first slot but it is not being counted:
Fixed in 6.0.436
F4-424 Pro
thierrys73 wrote: ↑07 Aug 2024, 04:55
The email notification service of the NAS has failed to connect to the mail server. This may be related to the network environment where the NAS is located, and further investigation is needed to identify the cause.
golgoth
Italy
Post by golgoth »
In 436 Syncthing does not enable.
golgoth wrote: ↑07 Aug 2024, 13:51
The app no more compatible with current TOS version, Please wait for the app update from community app developer.
thierrys73
France
TMroy wrote: ↑07 Aug 2024, 13:40
Hello
I use bond with 2 network
I could be the reason ?
Nothing has change from 5.1.145 in my network
Tnas Ip and port are the same.
Tnas online is ok so the network seem to be good no ?
And the system propose to me the update in 6.1.436 that's what i do.
All was good in the version 5.1.145 .
The issue is coming when i try the version 6.x.x
Help me please !
Tnas T6-423
Tnas F2-221
Can you expand the notifications dialogue to show the mail server details?
