I made a backup and restored the factory settings - everything was fixed.
TOS 6.0.694 (X86) is Released for Update
Re: TOS 6.0.694 (X86) is Released for Update
F5-221 | 7.0.0517 | 10GB RAM | 4x4.00TB Seagate IronWolf TRAID/BTRFS
F4-423 | 6.0.794-01324 | 32GB RAM | 2x512GB NVME System | 4x8.00TB Seagate IronWolf TRAID/BTRFS
I noticed that Docker does not restart automatically, I have to start it manually after every reboot.
We have not yet found a similar situation. Are you referring to a specific container or the Docler Engine/Docker Manager service?
If you have many services enabled, some may take longer to start. You can try waiting for a few minutes.
If Docker Engine/Docker Manager does not automatically start even after waiting, you can contact the official website's Live Chat to schedule a remote troubleshooting session.
Hello, I already noticed this issue previously that docker wasn't always starting automatically.
A solution to be sure that it will start is a scheduled task with the trigger "Power on" that execute the command "/etc/init.d/docker start"
We will keep an eye on the situation.
Once the issue arises again, please provide a system report (collected before shutting down) via the official website's Live Chat or technical support email. This may help us diagnose the problem. You can also schedule an engineer for remote troubleshooting if needed.
Thanks to both of you, now I'll try one of the solutions. These days I'm often out of the office so as soon as I can I'll check and let you know how it went. For now thanks!!
Docker Engine does not start, I only have immich in execution so not many appealing ... as soon as I can I try to wait but the ultima time I realized the next day so I would say that it is not a matter of waiting ... but I will definitely try again! A thousand thanks!TMzethar wrote: ↑19 Jun 2025, 17:34We have not yet found a similar situation. Are you referring to a specific container or the Docler Engine/Docker Manager service?
Is anybody experiencing a remote login issue by using TNAS Mobile app v3.4.016 ? I have my F2-422 configured with remote connection properly, but after pushing login, the app tries to upload the environment, but it remains on the uploading page, and I can't access the resources remotely. In the previous SW version, I never had this issue. I'd very glad for a feedback of the community. Tnx
- gladiator1138
android Mobile app(3.4.016) is not able to connecting to tos 6.0.694 version. It is supper annoying.
- sianderson
- Silver Member
while i cant confirm the android version, but IOS app (3.4.016) is able to connect to my F2-423 running 6.0.694 so the issue maybe something specific to your environmentgladiator1138 wrote: ↑04 Jul 2025, 13:46 android Mobile app(3.4.016) is not able to connecting to tos 6.0.694 version. It is supper annoying.
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
