TOS 5 Beta is released for testing NOW!
Charlie_Croker
Saudi Arabia
Re: TOS 5 Beta is released for testing NOW!
Post by Charlie_Croker »
@TMroy
Thank you, next time it happens, I will send over what you require.
krisprolls
Post by krisprolls »
Ok for info; after a reboot, the http interface doesn't accept again my password !
so it wasn't a question of not using special character.
it still works with aft and smb.
that is really annoying, as it is the least we can have for testing beta 5 I give up.
eulero
Italy
NOT able to enable PLEX
Post by eulero »
Ciao all,
updated to last TOS to XXX72; now I'm not able to enable Plex.
I tried to uninstal completely and instal again .... but nothing, not able to run again.
Thanks for your support
Eulero
krisprolls wrote: 17 Apr 2022, 17:56 Ok for info; after a reboot, the http interface doesn't accept again my password !
we need some error information when this issue happens. I wrote the instructions step by step on the
images so that you can better understand the steps. please follow the instruction and send us the screenshot. Appreciate!
https://www.jianguoyun.com/p/DXgZy6wQqPmkChiKg7kEIAA
https://www.jianguoyun.com/p/DSxZGlwQqPmkChigg7kEIAA
krisprolls
ok give me a mail I can send you the screen capture please.
krisprolls wrote: 18 Apr 2022, 14:09 ok give me a mail I can send you the screen capture please.
You can see it in our signature.
EgorA
Post by EgorA »
Hi!
Tell me please why I can't install most of applications?
Like Git from official repository ("Operation failed"),
SyncThing from here viewtopic.php?f=37&t=1515 (Warning Error! The file is incorrect and cannot be installed.)
TorrServer from here https://github.com/vladlenas/Terramaste ... /releases/ (Warning Error! The file is incorrect and cannot be installed.)
I have F2-221 with TOS 5.0.72-00088
Nouniard
Post by Nouniard »
Hello, I'm having trouble creating storage pools/volumes. No matter how many times I've tried, it won't do anything after I confirm a selection.
Current hardware: F4-220
Software: 5.0.72-00088
No currently configured Storage Pool/Volumes. Two 18TB HDD installed.
I've tried to do it from both the Volume and Storage Pool tabs:
VOLUME TAB:
Control Panel > Volume > Create > Create volume on a new Storage Pool
HDD1 18TB
HDD2 18TB
I select "With Data Protection" and "TRAID" > No HyperLock-WORM > EXT4 > Confirm
After I click Confirm, the button grays out and says "Configuring" with a spinning animation for about 3-4 seconds. The window then closes and nothing happens.
STORAGE POOL TAB:
Control Panel > Storage Pool > Create >
HDD1 18TB
HDD2 18TB
I select "With Data Protection" and "TRAID" > Confirm. A window with "Warning - All data contained...will be erased...continue?" pops up. I click "Confirm".
The Control Panel grays out and I see:
Storage Pool #1 0B/0B
Creating ... 0% > 10%
A blue circle spins a few times over about 3-4 seconds. Then the Control Panel is no longer grayed out and the Storage Pool shows nothing except "No Valid Data" and the Create button again.
{L_BUTTON_AT}EgorA
The application packages you mentioned is not suitable for TOS 5.
EgorA
Post by EgorA »
{L_BUTTON_AT}EgorA
2 questions:
- GIT is in official repository so it has to be suitable otherwise exlude it
- and what to do? Did developers were informed what to do?
