How to manually install 3rd Party Apps and the list with available apps
Re: How to manually install 3rd Party Apps and the list with available apps
try to access
http://yournasip:6363
Regarding 502 bad gateway, have you removed the TM version of qbittorrent ?
You may suffer the issue below
viewtopic.php?f=37&t=4171
emperorgr
Greece
Post by emperorgr »
with the http at port 6363 i get the qbitorrent web UI, the default username password is admin/adminadmin and download works ok :D
darkman030
Post by darkman030 »
I'm using Terramaster F2-210 and my tos version is 4
I downloded the AdGuardHome TOS4 0.107.16.0 aarch64 but the error message popped up.
Is there anything I can do to add this app? My language is set to English btw...
Edit the filename and replace the blank spaces with _ Or simply rename the file without spaces. TOS4 cannot handle blank space in filename.
darkman030
Thank you! I would never think of this...
JPadgett1993
Post by JPadgett1993 »
The app I installed shows up in my installed section under the app center. However, it won't allow me to enable it. Each time I try it says operation failed and goes back to being disabled. I suspect it's a security setting but I have no idea what to edit to allow it. Thanks!
Which app? And what is your OS and NAS model?
nativeit
Post by nativeit »
I've been waiting for some time now for an update to one of the apps, and since I am comfortably qualified to handle it myself, I went looking for the sourcecode for the .tpk files used in the app store, but have thus far been unable to locate any code repositories. Could you tell me where the source code is being hosted for the apps listed in the app store?
I'd love to help contribute to the effort. Thanks in advance for the info!
EthanBerg97
Norway
Post by EthanBerg97 »
Followed your tutorial for my NAS setup - absolutely flawless!
Righty01
Post by Righty01 »
Hi
I'm trying to find out have to install audiobookshelf but with no luck. Any chance for some help please in easy format .
Thank you
Jas
