[Help] I have 2 F5-221 devices but only 1 will update to TOS7  [SOLVED]
Re: [Help] I have 2 F5-221 devices but only 1 will update to TOS7
Whether using the boot file of the Init system or the boot file of the RAID system is feasible.
Since the faulty F5-221 failed due to the Init system's boot file, you can try re-burning the Init boot to the built-in USB of the faulty F5-221.
Alternatively, you can simply remove it, and the F5-221 will automatically use the boot file of the RAID system (If available).
ChadH42
Re: [Help] I have 2 F5-221 devices but only 1 will update to TOS7  [SOLVED]
Post by ChadH42 »
Physically removing the internal USB worked!!
Return to “Initialization”
