TOS 7.0.0333 Beta (X86) is Released for Update
Re: TOS 7.0.0333 Beta (X86) is Released for Update
System updated to 7.0.0333 today. No issues at all with update (using "download and update" function from GUI).
Will second this.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
F4-424 Pro
40TB storage.
TOS- 7.0.0746
Issue that showed up on.0309. When I open Plex on the TOS desktop it tries going to my TNAS IP address 100.x.x.x and not my server IP 192.x.x.x. I thought this was fixed after .0333 but today it is back to doing the same thing.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
F4-424 Pro
40TB storage.
TOS- 7.0.0746
Well noted, and added to bug list, waiting for verify and fix.
What did you mean? plex media server is not running on your tnas? when you open plex on your TOS desktop, it need to visit the same IP with your tnas but just different port, what am i missing?
Plex is running but if I try opening the app to work in the library or check for updates it will try going to the tnas remote IP:port address in the web browser. Unfortunately it won't load because it thinks it's not a valid address. On all the other releases it would go the local IP:port.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
F4-424 Pro
40TB storage.
TOS- 7.0.0746
Try clearing your browser cache?jpeckinp wrote: ↑01 Jan 2026, 10:01Plex is running but if I try opening the app to work in the library or check for updates it will try going to the tnas remote IP:port address in the web browser. Unfortunately it won't load because it thinks it's not a valid address. On all the other releases it would go the local IP:port.
connect LAN1 and LAN2
Ciao,
is it no more possible to connect both LAN ports for the F2-422?
Eulero
Eulero
Current System:
F2-422 - 4TB storage
TOS- 7.0.0333
TOS- 7.0.0333
can't update this way, after update is downloaded, it doesn't update but ask to download/update again, and so on...
the direct https://download3.terra-master.com/TOS% ... 171845.bz2 link should help. Will try now.
F5-221 | 7.0.0517 | 10GB RAM | 4x4.00TB Seagate IronWolf TRAID/BTRFS
F4-423 | 6.0.794-01324 | 32GB RAM | 2x512GB NVME System | 4x8.00TB Seagate IronWolf TRAID/BTRFS
