[Help] TNAS Network card keeps losing connection
TMjack
Re: [Help] TNAS Network card keeps losing connection
Post by TMjack »
Hello!
Could you please provide the current TOS version you are using? Additionally, could you tell me whether quite a few applications are installed in your TOS system? If possible, I suggest you temporarily disable the installed applications, keeping only the TOS system running, and then check if network disconnections still occur.
Additionally, could you please confirm whether the Media Indexing feature is enabled? (You can check this via Control Panel > Network Services > Media Indexing.) If so, please turn it off.
corycet
Post by corycet »
Can you provide directions on how to use Memtest 86+ for TNAS?
corycet wrote: 22 Aug 2025, 08:54 Can you provide directions on how to use Memtest 86+ for TNAS?
Sorry, we currently do not have relevant operation guidelines. You can refer to the user guide on the official website: https://www.memtest86.com/userguide.html
Return to “Network”
