Hi, sorry for that, our engineers will verify it later.
TOS 6.0.694 (X86) is Released for Update
Re: TOS 6.0.694 (X86) is Released for Update
Presume you have updated from TOS4 to Tos5.1.67
In which case you need to do a complete backup of all your data in the first instance. If you are really concerned have 2 backups in different places. With backups in place you can wipe your drives and start again to update the operating system partitions to 8GB (from 2GB) nominal. Probably best to do a new install of 5.1.145, remake your pools/volumes and reinstall a copy of your data.
At 5.1.145 you can (at least) directly re-install the TOS5.1 o/s in the event of any mishap. (When you then upgrade to TOS6, the internal usb flash drive will be re-written for TOS6, which makes re-installation of Tos5.1 more complex.).
If you need more info/help that you cannot find in the linked pages from earlier, perhaps post a new topic as it is not really appropriate in this thread.
following issue:
I updated from 6.0.688beta to 6.0.694 on F4-423. With 688 there was en entry for my SSD-systemdisk in the new menuitem "Harddisk->Systemdisk".
With 694 the menuitem "Harddisk->Systemdisk" is emty and all buttons are greyed.
Best Regards
following issue:
Best Regards
See second part of second post in this thread, which has not yet been answered
Ok, thank you. My whisfull thinking was, that the following posts start text "updated to 6.0.694 no problem,..." was related to your question.
I urgendly needed the new version because of the "save system configuration" fault with "bad gateway 502" in succession after reboot.
What are the current PC desktop and mobile app versions? I am unable to connect with the android app just a loading circle.
I have 5.2.186 for PC
and 3.4.016 for Android.
Current System:
F4-424 Pro
40TB storage.
TOS- 7.0.0746
F4-424 Pro
40TB storage.
TOS- 7.0.0746
I updated to 6.0.694 on my f2-423 & 3.4.016 is working OK for me on a Pixel 9 xl.
F2-423 TOS 7.0.1298 20GB RAM, 2x NVMe drives (.25TB + 1TB JBOD as Volume1), 2x 12TB TRAID as Volume2 D4-320 4x 8TB TRAID as Volume3
Hi, what is your NAS model and TOS version, mobile phone model and OS version?
