Public Beta Testing for TOS 6 ARM Version
impaladb
Re: Announcement of Public Beta Testing for TOS 6 ARM Version
Post by impaladb »
GevinKe wrote: 18 Apr 2025, 10:29
impaladb wrote: 18 Apr 2025, 08:23 Just setup a new F4-212 2GB. So far all is working well. The 212 is an offsite location to backup an onsite F4-423. Duple backup is still not working between ARM and x86 so have to use RSYNC. I'm not using docker or any media sharing as this is strictly standard file services.
Hi! Are you planning to back up the data from the F4-212 device to the F4-423 device using Duple Backup? To provide more accurate advice, could you please share the following details:
1. The TOS version number of both the F4-212 and F4-423 devices.
2. The version numbers of Duple Backup and Duple Backup Vault on both devices.
Additionally, could you clarify the specific issue you are facing? Are the two devices unable to establish a connection, or have they connected but the backup process is failing?
Per your previous post of Nov 5, 2024: I'm very sorry for the inconvenience, but currently DupleBackup does not support mutual backup between devices with X86 architecture (F2-424) and those with ARM architecture (F2-212). We have already reported this issue to our product team for consideration and optimization. Thank you for your understanding and patience.
impaladb wrote: 26 Apr 2025, 20:10
After upgrading to TOS6 ARM, Duple Backup for x86 and ARM now support mutual backups.
Captain8836
Post by Captain8836 »
Captain8836 wrote: 15 Apr 2025, 05:17 I want to install the new TOS6 on my F2-212. To anyone who has installed it, how is it working? Is it working well, or should I wait?
Upgraded F2-212 to TOS6, no problems.
OrionXie
Saudi Arabia
Post by OrionXie »
Captain8836 wrote: 30 Apr 2025, 16:08
Thank you for your feedback. What suggestions and questions are there for subsequent use? Please keep in touch with technical support via email or LiveChat. Wish you a lucky day
dikol
Re: Public Beta Testing for TOS 6 ARM Version
Post by dikol »
Installed TOS 6 on a test HDD (Seagate Barracuda ST3500413AS 500Gb) via update. Overall, I liked it. It works quickly. The system boots faster. Rebooting is also faster. TOS 5 applications are installed and work. Third-party applications from the site https://tmnascommunity.eu/ are installed and work (ttyd did not work), but launching from the desktop gives errors - or (no access, please login on TOS with admin account), or (Access denied!) - you need to login on TOS with an admin role account.
Entware is installed. It is also possible to install Ubuntu/Debian packages from the "apt list"
There is a media group, but it is not displayed in the settings. I added users plex and torrent to the allusers group, then only Plex and qBittorrent started working normally.
Cron, after reboot does not work. The /var/spool/cron/crontabs folder is empty. The file in the /etc/crontabs folder is in place. I launch "crontab -e", the file only contains a description, without commands for cron.
I am interested in the question of support for SNMP. SNMP after installation from packages works on reception. On return only from address 127.0.0.1
TNAS F4-212 2Gb TOS 5.1.73 2x4Tb Seagate SkyHawk ST4000VX016 2x8Tb Seagate Ironwolf ST8000VN004
TNAS F4-210 1Gb TOS 4.2.44 2x2Tb HGST HUA723020ALA640, 1x4Tb Seagate SkyHawk ST4000VX016
Fabbrox96
Italy
Post by Fabbrox96 »
Hi all, do you know if docker engine works, without docker manager? I would like to install TOS 6 but I don't want to lose the functionality of docker
rleitao
Portugal
Post by rleitao »
Hi All,
I am having a issue with DDNS with no-ip, user information is correctly inserted but it wont connect the status is always disconnected, is this a known issue at the moment? and will a future update resolve this or will i need to downgrade back to TOS 5 to resolve this?
Regards and thank you in advance for any assistance.
OrionXie
Saudi Arabia
Post by OrionXie »
rleitao wrote: 15 May 2025, 18:02
Thank you for your feedback. We have already forwarded your issue to our laboratory. We will conduct further tests and make determinations. Have a pleasant day.
dikol
Post by dikol »
OrionXie wrote: 16 May 2025, 14:53 We have already forwarded your issue to our laboratory.
Will you check the operation of Cron?
hk87
Germany
Post by hk87 »
My test system is F2-212 and the installation of TOS 6.0 went smoothly and without errors. However, there are difficulties when reinstalling Docker. This is not displayed in the application and cannot be found in the store. The Snapshot and MultimediaServer apps were ready to start immediately.
