i wasnt sure if i would be creating some kind of fire risk if i was to stick it down like that, its definitely a job for another day when i want to use that 2nd slot or until it niggles at me too much to do a proper jobGremlin wrote: ↑07 Aug 2025, 18:29Hmm. Your conundrum prompted me to pop the cover off my -424 unit. I would suggest in the interim maybe some double sided tape on the underside of the nvme or, possibly some 'velcro' if it's not too thick. If you need a long term solution maybe a very fine dremel (other brands are available) cut across the top of the screw stub (and locator) might allow the stub to be removed with a small, flat bladed jeweller's screwdriver. You will, of course, need to be heedful of debris. Again some of the ubiquitous double-sided tape around the locator before cutting might help contain particles.
Disclaimer: All activities at your own risk![]()
How to Properly Replace, Add, or Move RAM and M.2 NVMe SSD?
- sianderson
- Silver Member
Re: How to Properly Replace, Add, or Move RAM and M.2 NVMe SSD?
F2-424 TOS 7.0.1140
F2-423 TOS 7.0.1140
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1140
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
