HTTPS not working
designdev
Netherlands
Re: HTTPS not working
Post by designdev »
Alaster wrote: ↑23 Feb 2025, 17:29 I do have the same problem. The remote link is with "https" but after pressing enter, it cancelled the "https". I hope this can be resolved as a lot of company cannot accept non secure link.
Hi Alaster I’ve seen that issue before. It’s often caused by the NAS or router dropping SSL redirection, or the web server config forcing HTTP.
A few things to try: (it's is my personal advice for you)
    Ensure your TerraMaster is set up with a valid SSL certificate (Let’s Encrypt or custom).
      Check the web service settings so “redirect HTTP → HTTPS” is enabled.
        If using a reverse proxy or firewall, make sure it’s forwarding HTTPS correctly.
        Did you manage to access the NAS web interface over HTTPS at all (even temporarily)?
        Return to “Network”
