TOS 4.1.30 is released for update
Re: TOS 4.1.30 is released for update
Re downloaded the X86 version in seconds...hopefully it will behave the .29 version was stable for a day or so then kept disappearing from the net work and now its been stable for a few days strange.
First attempt failed to update.....second OK CPU and RAM are now down lets hope the CPU exceeded 90% notification on a regular basis has stopped...seems that the CPU usage is still being reported as high 60% see process screen shot.
that threat ist bullshit!
viewtopic.php?f=75&t=423
when i Try do take the copy i downloaded, it doesn't reconnize the.
If I take " downloa from blbla" over one hone hour it happenes nothing!
So tell me what to do noW!
Over an hourse nothng happens,
and aly tried to pluss the disk out, restart the nas without the HDD but nothing!
what did you do? Did you update your TOS or you re-install it?
I was now on the TerraMaster webite, under "Download" there is no tos Version for the F4-210.
Thats why it can't download it manually.
What schould i do now?
Please follow the instructions to download the new update package viewtopic.php?f=28&t=711
I have no more acces to the Terramaster interfaceTMroy wrote: ↑11 Aug 2020, 21:44 Please follow the instructions to download the new update package viewtopic.php?f=28&t=711
- sianderson
- Silver Member
thank you for this update, early testing is looking superb
F2-210 booted up after the update and sat at 27% Ram usage
copied 3 files off the nas drive (3gb each) and the ram went up to 28% on previous versions this would have shot up to 99%
i dont know if this is relevant also i was a little concerned that transfer rates had dropped to 30 - 40mb/s on previous versions, however these files flew off the nas drive at 100 - 110mb/s
F2-424 TOS 7.0.1140
F2-423 TOS 7.0.1140
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1140
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
