Email reporting doesn't work TOS 6
Re: Email reporting doesn't work TOS 6
SDeath wrote: ↑06 Dec 2024, 19:00
According to the Kerio Mail server 6 documents (only a brief scan admittedly) their exemplar setup shows Port 465 for SMTPS + ONLY set up for secure mail service (paraphrasing), which is the same port specified by my mail carrier.
So, I use 'custom' on TNAS with the domain address of the server {in my case Dynu's smtp server 'smtp.dynu.com'} with the port set as 465 and authentication method of TLS/SSL.
You do have to enter the password for the designated email user name on the TNAS every time before you can run a test (even after it is successfully set up, which is a nuisance but I guess someone at TM feels it a needed security step :?: - or just bad programming :!: ).
If you cannot see the authentication method expand the dialogue window until the drop-down remains visible (see last point above).
If you have not followed Kerio's advice for secure setup, that is something I cannot help with, unfortunately.
Good Luck.
{And, for those "doubters" who did not like my previous post, I achieved all this by searching the web, reading the content I found and working it out. If you need spoon feeding go elsewhere.}
witchy
Post by witchy »
That was it! Thanks, it was driving me mad that I couldn't select TLS.
So, for me it's smtp.gmail.com, port 587, SSL/TLS and an App Password :D
Cheers
Witchy
rpancha08 wrote: ↑03 Jan 2025, 04:20
A step by step guide to use Gmail as smtp server in TOS6
https://tmnascommunity.eu/2025/01/08/ho ... l-in-tos6/
Return to “Network”
