Release Notes for x86 Series TOS Update!
mmalchuk
Re: Release Notes for x86 Series TOS Update!
Post by mmalchuk »
V8Triker wrote: ↑27 Jan 2025, 21:52
I've successfully restored 5.1.145 to my F5-221, but I really want 6.x. The last working version I've tested is TOS_X642.0_Update_6.0.530_00148_2410300306
F5-221 | 7.0.0517 | 10GB RAM | 4x4.00TB Seagate IronWolf TRAID/BTRFS
F4-423 | 6.0.794-01324 | 32GB RAM | 2x512GB NVME System | 4x8.00TB Seagate IronWolf TRAID/BTRFS
lichkingxxl
Spain
Post by lichkingxxl »
My F4-421 cannot be updated to version 6.0.530 due to the BIOS/InitBoot version. When will those of us with older BIOS versions be able to install TOS6? Is a specific version for our case being worked on?
Thanks.
crisisacting
Post by crisisacting »
sophia450 wrote: ↑30 Jan 2025, 22:20
Ban this bot/crypto bullshit
Edit: ↓
This account has been banned, sorry for that.
crisisacting
TMroy wrote: ↑30 Jan 2025, 22:47
Appreciate the action to remove that obvious spammer.
lcappelletti
Italy
Post by lcappelletti »
I have:
TERRAMASTER F5-422 5-Bay 10GbE NAS CPU Quad-Core 8GB RAM - May 2022
TerraMaster F5-420 NAS Server 5-Bay Intel Quad Core 2.0GHz 4GB RAM May 2018
for the F5-420
viewtopic.php?t=6984
from here I Followed all the step
Update sequence: (TOS 4.2.44---TOS 5.0.XX) → TOS 5.0.176 → TOS 5.1.24 → (TOS 5.1.145---6.0.229) → TOS 6.0.530 → Latest version of TOS 6
but is stuck from TOS 5.1.24 to TOS 5.1.145 uploading the software package... 83%
1) how to solve this? is from yesterday
2) if I understand I cannot upgrade to TOS 6, right?
TNAS F5-422
as it was bought in May 2022 should be upgraded, right?
thanks in advance
IrisLi
Post by IrisLi »
You can check the following aspects and let us know the results, which will help us identify the cause of the problem:
Check if there is sufficient remaining storage space.
Check if the system partition is 8GB.
Check if there is a network issue.
lcappelletti
Italy
TMqiky wrote: ↑05 Feb 2025, 21:58 You can check the following aspects and let us know the results, which will help us identify the cause of the problem:
for 420
1st question, no.
/dev/md0 7738763684 7658989216 40756280 100% /Volume1
[xxx@TNAS1~]# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 1.8T 0 disk
|-sda1 8:1 0 285M 0 part
|-sda2 8:2 0 1.9G 0 part
| `-md9 9:9 0 1.9G 0 raid1 /
|-sda3 8:3 0 977M 0 part
| `-md8 9:8 0 976.4M 0 raid1 [SWAP]
`-sda4 8:4 0 1.8T 0 part
`-md0 9:0 0 7.3T 0 raid5 /Volume1
sdb 8:16 0 1.8T 0 disk
|-sdb1 8:17 0 285M 0 part
|-sdb2 8:18 0 1.9G 0 part
|-sdb3 8:19 0 977M 0 part
`-sdb4 8:20 0 1.8T 0 part
sdc 8:32 0 1.8T 0 disk
|-sdc1 8:33 0 285M 0 part
|-sdc2 8:34 0 1.9G 0 part
|-sdc3 8:35 0 977M 0 part
`-sdc4 8:36 0 1.8T 0 part
sdd 8:48 0 1.8T 0 disk
|-sdd1 8:49 0 285M 0 part
|-sdd2 8:50 0 1.9G 0 part
|-sdd3 8:51 0 977M 0 part
`-sdd4 8:52 0 1.8T 0 part
sde 8:64 0 1.8T 0 disk
|-sde1 8:65 0 285M 0 part
|-sde2 8:66 0 1.9G 0 part
|-sde3 8:67 0 977M 0 part
`-sde4 8:68 0 1.8T 0 part
[xxx@TNAS1~]# df -h
Filesystem Size Used Avail Use% Mounted on
/dev/md9 1.9G 1.5G 307M 83% /
devtmpfs 1.9G 0 1.9G 0% /dev
tmpfs 1.9G 28K 1.9G 1% /dev/shm
tmpfs 1.9G 19M 1.9G 1% /tmp
tmpfs 1.9G 324K 1.9G 1% /run
tmpfs 1.9G 5.8M 1.9G 1% /opt/var
/dev/md0 7.3T 7.2T 39G 100% /Volume1
[lcappelletti@TNAS1-Luke ~]#
2nd question
From the documentation mentioned, is a manual update. all the previous are done correctly. is failing TOS 5.1.24 → TOS 5.1.145
I can telnet FTP etc etc.
for 422
[lcappelletti@TNAS2-LUKE ~]# df -h
/dev/md9 7.5G 1.5G 5.6G 21% /
devtmpfs 3.8G 0 3.8G 0% /dev
tmpfs 3.9G 48K 3.9G 1% /dev/shm
tmpfs 3.9G 28M 3.8G 1% /tmp
tmpfs 3.9G 408K 3.9G 1% /run
tmpfs 3.9G 114M 3.7G 3% /opt/var
/dev/mapper/vg0-lv0 59T 51T 7.2T 88% /Volume1
/dev/mapper/vg0-lv0 59T 51T 7.2T 88% /home
/dev/mapper/vg0-lv0 59T 51T 7.2T 88% /usr/lib/virtualbox
cgroup 3.9G 0 3.9G 0% /sys/fs/cgroup
/dev/mapper/vg0-lv0 59T 51T 7.2T 88% /Volume1/@DockerData
[xxx@TNAS2 ~]#
TMjack
Post by TMjack »
Hello, based on the information you provided, since your TOS system partition is only 2GB and considering the hardware limitations of the 420 series models, your device currently does not support upgrading to TOS 6.
lcappelletti
Italy
Thanks, for the replay,
but why but is stuck from TOS 5.1.24 to TOS 5.1.145 uploading the software package... 83%
Please see the screenshot posted.
