TOS 6.0.530 Official Version Released
star
Sweden
Re: TOS 6.0.530 Official Version Released
Post by star »
Got failed to update when updateing from 5.1.145 on t6-423
quella
Post by quella »
Upgrade from 5.1.145 seems to have gone well, but the configuration was cleared (data there but users/permissions removed). Not a big deal as I did not have a bunch of users. Overall the system does seem faster and more responsive.
I am having an issue trying to get my Macintosh Time Machine folder (TMACHINE) shared out once again as this was previously working prior to the upgrade. I have a Volume2 for this folder and when I check available disks from a Mac, it only seems to be showing "TNAS_Name Public" which is on stored on Volume1. Is there a way to ensure Time Machine from the mac can once again see the TMACHINE folder on Volume2?
star
Sweden
Post by star »
my update from 5.1.145 fails from the usb boot loader it seems
quella
Post by quella »
I believe I'm all set on the Time Machine configuration. It did require me to install and configure BACKUP which I think was a default app in 5.1.145, but not in v6.0. Testing now as I was able to now select the TMACHINE folder and remove Public.
liability
Australia
Post by liability »
I just updated from 6.0.519 on a spare F2-221, everything seems to work.
addx972
France
Post by addx972 »
can we change the installation location of this update or not
star wrote: ↑05 Nov 2024, 05:23 my update from 5.1.145 fails from the usb boot loader it seems
Are you saying that the upgrade package is not available here in TOS > Control Panel > General Settings > System, and that it automatically goes to the Initialization/Bootloader page?
That's not normal. In order to find out the problem you encountered, we can arrange for you to have an engineer to investigate the problem remotely.
If you agree, please contact our technical support mailbox or the customer service window on the homepage of our website to schedule an appointment. Please remember to provide them with a link to this post.
usersky wrote: ↑04 Nov 2024, 19:39 I just installed it on F5-221 not seeing it's not on the list. Not that I'd recommend doing this to anyone but till now at least I can see all the files in the internal volume/pool. However on the external drive attached via USB it reports as being empty, still investigating.
Haven't observed anything like this yet, will keep an eye out for it. Can you tell us the version of TOS before you used the upgrade package? Are your USB devices used as USB external storage or as storage pools & volumes?
star
Sweden
Post by star »
TMzethar wrote: ↑05 Nov 2024, 09:02
star
Sweden
Post by star »
when i add the support pack and click update it will say failed update and usb bootloader will be mounted and corrupted.
so yeah its not working .
it worked perfect to update to 5.1.145
