Can't access Plex Media Server folder continued
plexjellyfin
Re: Can't access Plex Media Server folder continued
Post by plexjellyfin »
they pushed a new update today regarding permissions try the update. If not create an entirely new folder and before you move anything over make sure all the permissions are set. I would then recommend moving over 1 folder to test.
Hope that helps.
beagle062
Post by beagle062 »
Hi Plexjellyfin,
Plex is now able to successfully scan my media in sub-folders in the “Shared Folder”
1 - I updated my TOS to the newly released TOS 6.0.513.
2 - in TOS, I used Edit Shared Folder checkbox option to “Replace the permissions of all the subdirectories with the permissions of the folder”
3 - Next, I assigned application user (plex) read/write permission on the share /Volume1/_Movies-Archive
The TOS 6.0.513 update fixed the permission issue for me. The TOS update release notes said there were permission fixes added to TOS 6.0.513 update. I guess the security permissions updates fixed the issue.
Thank you all!!!
It appears that the Plex application user account (plex) cannot browse or transverse the sub-folders below the TNAS shared folder.
beagle062
Post by beagle062 »
Ignore line "It appears that the Plex application user account (plex) cannot browse or transverse the sub-folders below the TNAS shared folder."
The text is a cut & paste error left over from previous message.
Nick10
Post by Nick10 »
Hi how do I find app permissions on TOS 3?
Nick10
Post by Nick10 »
plexjellyfin wrote: 04 Oct 2024, 10:20
will updating from TOS 3 erase my data?
sim667
Post by sim667 »
lam3094 wrote: 13 Oct 2024, 03:55 Thank you all for the help on this. I had followed the same information as plexjellyfin and that had fixed the problem. I managed to get plex to recognise the folder now...however, I can see the media inside the folder (.avi, .mp4 etc files) and added this as a library, but when it tries to load the category e.g films, it comes up as "Films" is empty. I know that they all work as my current Plex Server files have all just been moved over there. I have also tested it with just a few files to see if the same thing happens (which it does.)
Have you checked the permissions of the files themselves?
I'm a keen plex user, and plex not recognizing media is almost always permissions based
Return to “Plex Media Server”
